So first i see this video . https://www.youtube.com/watch?v=Dp3RMb0e1eA&list=PLVilroPGLJaesaS5mP93i0goPck2JK-O4&index=3
Second i download the libhttps://github.com/indrekluuk/LiveOV7670
and i install it
Third i open the example code ”不相容“ means “incompatible”
here is the code ,
Example for Adafruit_OV7670 library. With an ILI9341 TFT shield and
OV7670 camera connected to Grand Central, displays a continuous live
feed. That's all, keeping this a fairly minimal example.
US
HARDWARE REQUIRED:
- Adafruit Grand Central board
- Adafruit 2.8" TFT Touch Shield (touch is NOT USED in this example)
- OV7670 camera w/2.2K pullups to SDA+SCL, 3.3V+GND wires to shield
#include <Wire.h> // I2C comm to camera
#include "Adafruit_OV7670.h" // Camera library
#include "Adafruit_ILI9341.h" // TFT display library
// CAMERA CONFIG -----------------------------------------------------------
#if defined(__SAMD51__) // Grand Central or other M4 boards
// Set up arch and pins structures for Grand Central's SAMD51.
// PCC data pins are not configurable and do not need specifying.
OV7670_arch arch = {.timer = TCC1, .xclk_pdec = false};
OV7670_pins pins = {.enable = PIN_PCC_D8, .reset = PIN_PCC_D9,
.xclk = PIN_PCC_XCLK};
#define CAM_I2C Wire1 // Second I2C bus next to PCC pins
#endif // end __SAMD51__
#define CAM_SIZE OV7670_SIZE_DIV2 // QVGA (320x240 pixels)
#define CAM_MODE OV7670_COLOR_RGB // RGB plz
Adafruit_OV7670 cam(OV7670_ADDR, &pins, &CAM_I2C, &arch);
// SHIELD AND DISPLAY CONFIG -----------------------------------------------
// TFT shield pinout. Switch these if using Feather (DC=10, CS=9)
#define TFT_DC 9
#define TFT_CS 10
#define TFT_SPI SPI
// Screen DMA allows faster updates, but USE_SPI_DMA must be
// manually enabled in Adafruit_SPITFT.h (it's not on by default
// on Grand Central). If DMA is not enabled there, a helper class
// makes screen writes a little bit faster (but not in background
// like with DMA).
#if !defined(USE_SPI_DMA)
#include "SPIBrute.h" // Direct-to-SPI-registers helper class for SAMD51
#endif
Adafruit_ILI9341 tft(&TFT_SPI, TFT_DC, TFT_CS);
#if defined(USE_SPI_BRUTE)
SPIBrute brute(&TFT_SPI);
#endif
// SETUP - RUNS ONCE ON STARTUP --------------------------------------------
//while (!Serial);
Serial.println("Hello");
// 50 MHz to screen is OK if wiring is clean (e.g. shield or FeatherWing).
// Otherwise (if using jumper wires to screen), stick to 24 MHz.
TFT_SPI.setClockSource(SERCOM_CLOCK_SOURCE_100M);
tft.begin(50000000);
#else
tft.begin(24000000);
#endif
tft.setRotation(3); // Match camera orientation on Grand Central
tft.fillScreen(ILI9341_BLACK);
brute.begin();
#endif
// Once started, the camera continually fills a frame buffer
// automagically; no need to request a frame.
OV7670_status status = cam.begin(CAM_MODE, CAM_SIZE, 30.0);
if (status != OV7670_STATUS_OK) {
Serial.println("Camera begin() fail");
for(;;);
uint8_t pid = cam.readRegister(OV7670_REG_PID); // Should be 0x76
uint8_t ver = cam.readRegister(OV7670_REG_VER); // Should be 0x73
Serial.println(pid, HEX);
Serial.println(ver, HEX);
// MAIN LOOP - RUNS REPEATEDLY UNTIL RESET OR POWER OFF --------------------
// TFT setAddrWindow() involves a lot of context switching that can slow
// things down a bit, so we don't do it on every frame. Instead, it's only
// set periodically, and we just keep writing data to the same area of the
// screen (it wraps around automatically). We do need an OCCASIONAL
// setAddrWindow() in case SPI glitches, as this syncs things up to a
// known region of the screen again.
#define KEYFRAME 30 // Number of frames between setAddrWindow commands
uint16_t frame = KEYFRAME; // Force 1st frame as keyframe
// This was for empirically testing window settings in src/arch/ov7670.c.
// Your code doesn't need this. Just keeping around for future reference.
if(Serial.available()) {
uint32_t vstart = Serial.parseInt();
uint32_t hstart = Serial.parseInt();
uint32_t edge_offset = Serial.parseInt();
uint32_t pclk_delay = Serial.parseInt();
OV7670_frame_control((void *)&cam, CAM_SIZE, vstart, hstart,
edge_offset, pclk_delay);
if (++frame >= KEYFRAME) { // Time to sync up a fresh address window?
frame = 0;
#if defined(USE_SPI_DMA)
tft.dmaWait(); // Wait for prior transfer to complete
#elif defined(USE_SPI_BRUTE)
brute.wait();
#endif
tft.endWrite(); // Close out prior transfer
tft.startWrite(); // and start a fresh one (required)
// Address window centers QVGA image on screen. NO CLIPPING IS
// PERFORMED, it is assumed here that the camera image is equal
// or smaller than the screen.
tft.setAddrWindow((tft.width() - cam.width()) / 2,
(tft.height() - cam.height()) / 2,
cam.width(), cam.height());
// Pause the camera DMA - hold buffer steady to avoid tearing
cam.suspend();
//cam.capture(); // Manual capture instead of PCC DMA
// Postprocessing effects. These modify a previously-captured
// image in memory, they are NOT in-camera effects.
// Most only work in RGB mode (not YUV).
//cam.image_negative();
//cam.image_threshold(150);
//cam.image_posterize(5); // # of levels
//cam.image_mosaic(21, 9); // Tile width, height
//cam.image_median();
//cam.image_edges(4); // 0-31, smaller = more edges
if(CAM_MODE == OV7670_COLOR_YUV) {
cam.Y2RGB565(); // Convert grayscale for TFT preview
// Camera data arrives in big-endian order...same as the TFT,
// so data can just be issued directly, no byte-swap needed.
// Both the DMA and brute cases handle this.
tft.dmaWait();
tft.writePixels(cam.getBuffer(), cam.width() * cam.height(), false, true);
brute.wait();
brute.write((uint8_t *)cam.getBuffer(), cam.width() * cam.height() * 2);
#else
#endif
cam.resume(); // Resume DMA to camera buffer
I run it .it shows this
i use uno board .
