I upload code to wifi shield but I can't connect to IP address
I use Arduino wifi shield (Chip: AMTEL 32UC3A1512) and Arduino Uno Rev 3.
I have update Arduino wifi shield firmware to version 1.1.0. (Is it the latest version?)
I upload WiFiChatServer (http://arduino.cc/en/Tutorial/WiFiChatServer) ,and I get IP address.
But when I paste IP to browse(Google chrome), browse can't connect to IP address.
I have ues two Encryption Type, none and WPA2. (Smart phone connect to 3G and then share network), but still can not connect by browse.
By the way, since I update Arduino wifi shield firmware to version 1.1.0 it's often happen "WiFi shield not present".
I have remove DFU jumper, but still happen this problem easier.
How do I resolve these problem?
That example is really not for a web browser. It is more for a telnet app. If you want to try to connect with a web browser, you must either change the server port from 23 to 80, or append the port to the ip in the browser address bar like this:
http://192.168.1.2:23
HI
I try to use another example (WIFI web server, http://arduino.cc/en/Tutorial/WiFiWebServer), but still can not connect
Arduino Wifi shield "LINK" is light.
In the Wifi web server example code:
WiFiClient client = server.available();
if (client) {
Serial.println("new client");
I open Serial Monitor, only have SSID, IP Address and RSSI.
So I think server.available is always false(0), is not true(1).
I try to use WiFiServer server(80), but still have this problem.
Oh My God, I reslove this problem.
BECAUSE int keyIndex = 0;
I set password total 8 words,but I write int keyIndex = 0;
correct is int keyIndex = 8;
