I wanna turn on led by bluetooth, but turn off by piezoelectric effect element
I already have .apk by app inventor2. So I think I have problem with code. but I don't know arduino well. That's why I need your help Here is my code
define ON 1
define OFF 0
define LED_PIN 13
define Pie 8
void setup() { // put your setup code here, to run once: pinMode(LED_PIN,OUTPUT); pinMode(Pie, INPUT); Serial.begin(57600);
do {
unsigned char rxBuf =0;
if (Serial.available()) { rxBuf = Serial.read();
switch(rxBuf) { case '0': digitalWrite(LED_PIN, ON); delay(500); digitalWrite(LED_PIN,OFF); delay(500); Serial.println("LED On"); break; case '1':digitalWrite(LED_PIN, OFF); Serial.println("LED Off"); break; } } while(digitalRead(Pie,On))
I need led blinking before Pie have digital signal
When I compile the code, problem is came at " do { ". Plz help me
What do you think this does
if Pie On, stop blink led. Am I right?
What makes pin 8 go high? What makes it low? How do you know what state it's in?
korLIM: When I compile the code, problem is came at " do { ".
See https://www.arduino.cc/en/Reference/DoWhile
if external simulate is represent, Pie can make eletricity. So i want to use this eletricity to On
What?
do {
You're missing something between the end of setup() and the "do {".
