I want beautiful effects
Healthy. I bought ice matrix 8x32. I have the Scrolling Parole program. I was chibu. I’ll send a chib’s [co. Also the whole pro// Use the Parola library to scroll text on the display
// Demonstrates the use of the scrolling function to display text received
// from the serial interface
// User can enter text on the serial monitor and this will display as a
// scrolling message on the display.
// Speed for the display is controlled by a pot on SPEED_IN analog in.
// Scrolling direction is controlled by a switch on DIRECTION_SET digital in.
// Invert ON/OFF is set by a switch on INVERT_SET digital in.
// UISwitch library can be found at https://github.com/MajicDesigns/MD_UISwitch
// MD_MAX72XX library can be found at GitHub - MajicDesigns/MD_MAX72XX: LED Matrix Library
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// set to 1 if we are implementing the user interface pot, switch, etc
#define USE_UI_CONTROL 0
#if USE_UI_CONTROL
#include <MD_UISwitch.h>
#endif
// Turn on debug statements to the serial output
#define DEBUG 0
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::PAROLA_HW
#define MAX_DEVICES 4
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// HARDWARE SPI
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// Scrolling parameters
#if USE_UI_CONTROL
const uint8_t SPEED_IN = A5;
const uint8_t DIRECTION_SET = 8; // change the effect
const uint8_t INVERT_SET = 9; // change the invert
const uint8_t SPEED_DEADBAND = 5;
#endif // USE_UI_CONTROL
uint8_t scrollSpeed = 25; // default frame delay value
textEffect_t scrollEffect = PA_SCROLL_LEFT;
textPosition_t scrollAlign = PA_LEFT;
uint16_t scrollPause = 2000; // in milliseconds
// Global message buffers shared by Serial and Scrolling functions
#define BUF_SIZE 75
char curMessage[BUF_SIZE] = { “” };
char newMessage[BUF_SIZE] = { “Hello! Enter new message?” };
bool newMessageAvailable = true;
#if USE_UI_CONTROL
MD_UISwitch_Digital uiDirection(DIRECTION_SET);
MD_UISwitch_Digital uiInvert(INVERT_SET);
void doUI(void)
// set the speed if it has changed
int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 10, 150);
if ((speed >= ((int16_t)P.getSpeed() + SPEED_DEADBAND)) ||
(speed <= ((int16_t)P.getSpeed() - SPEED_DEADBAND)))
P.setSpeed(speed);
scrollSpeed = speed;
PRINT("\nChanged speed to ", P.getSpeed());
if (uiDirection.read() == MD_UISwitch::KEY_PRESS) // SCROLL DIRECTION
PRINTS("\nChanging scroll direction");
scrollEffect = (scrollEffect == PA_SCROLL_LEFT ? PA_SCROLL_RIGHT : PA_SCROLL_LEFT);
P.setTextEffect(scrollEffect, scrollEffect);
P.displayClear();
P.displayReset();
if (uiInvert.read() == MD_UISwitch::KEY_PRESS) // INVERT MODE
PRINTS("\nChanging invert mode");
P.setInvert(!P.getInvert());
void readSerial(void)
static char *cp = newMessage;
while (Serial.available())
*cp = (char)Serial.read();
if ((*cp == ‘\n’) || (cp - newMessage >= BUF_SIZE-2)) // end of message character or full buffer
*cp = ‘\0’; // end the string
// restart the index for next filling spree and flag we have a message waiting
cp = newMessage;
else // move char pointer to next position
cp++;
Serial.begin(57600);
Serial.print("\n[Parola Scrolling Display]\nType a message for the scrolling display\nEnd message line with a newline");
#if USE_UI_CONTROL
uiDirection.begin();
uiInvert.begin();
pinMode(SPEED_IN, INPUT);
doUI();
P.begin();
P.displayText(curMessage, scrollAlign, scrollSpeed, scrollPause, scrollEffect, scrollEffect);
#if USE_UI_CONTROL
doUI();
if (P.displayAnimate())
if (newMessageAvailable)
strcpy(curMessage, newMessage);
newMessageAvailable = false;
P.displayReset();
readSerial();
gram. Pray for advice and help.
I was chibu. I'll send a chib's
What does that mean?
Please read the "How to use this forum - please read" post at the top of any of the boards and learn the forum rules especially as they relate to posting code. Please use code tags.
Was there a question in there somewhere?
"I want beautiful effects."
Staying away on this one :-X
I bought ice matrix 8x32. I have the Scrolling Parole program. I was chibu. I'll send a chib's [co. Also the whole pro
Even babbel could not translate that into English....
Regards, Ray L.
Healthy. I do not know English well. I have a problem with the program. Lists the problem. Want to repair the code.
atilka25: Healthy. I do not know English well. I have a problem with the program. Lists the problem. Want to repair the code.
You should find a forum in the language you speak then. There are many languages covered on this forum.
Nobody can help you fix the problem if you won't tell what the problem is.
The program you are listing is one of the example programs from the library. If you have not made any changes it should work. What is your question? What is not working?
Good marco. Thank you for your response. The problem is that it lists exit status 1. I have Win.7 / 64. Arduino ide 1.6.5. Arduino uno. The program does not accept Arduino going. Well thank you.
The error message is always longer than “exit status 1”. Use the “copy error messages” button and paste it here. Use the full reply editor and the </> button to format the error properly.
Healthy. I know that the code is fine from the library. Only Arduino is a bad person. Already in compilation shows chibu. I do not even have Arduino connected. How do I remove the chibu? Thank you for your advice.
Uverejnite celé chybové hlásenie. Existuje viac ako len "error status 1"
Healthy. Thank you for your response. It's already a story, though. What should I prepress? Thanks for advice.
Healthy. It’s working now. I have the opposite. How is it porous? Well thank you.
Inštalovali ste obaja MD_Parola.ha MD_MAX72xx.h?
Healthy. Yes, I have installed. MD Max 72XX. MD Max Panel. MD Password. The Max72xx Test is installed. It is opposite. Please advise. Well thank you.
Arduino: 1.6.7 (Windows 7), Vývojová doska:"Arduino/Genuino Uno"
WARNING: Spurious .github folder in 'Adafruit Motor Shield library' library WARNING: Category 'Display, Hangul' in library LiquidCrystal_I2C_Hangul is not valid. Setting to 'Uncategorized' In file included from C:\Users\Hrotko Attila\Documents\Arduino\libraries\MD_Parola\examples\Parola_Scrolling\Parola_Scrolling.ino:16:0:
C:\Users\Hrotko Attila\Documents\Arduino\libraries\MD_Parola\src/MD_Parola.h:388:24: fatal error: MD_MAX72xx.h: No such file or directory
compilation terminated.
exit status 1 Chyba pri kompilácii.
Tento výpis by mal viac informácií s "Zobraziť viac informácií počas kompilácie" povolené v Súbory > Vlastnosti.
There is your real error:
Is the library installed correctly? Is it inside a folder called MD_MAX72xx or does it have “_master” appended by GitHub?
Did you use the correct <> or “” around the library name? Use <> when it’s in the standard Arduino libraries folder. Use “” when it’s inside the current sketch folder.
Healthy. Thank you for your response. Max72xx libraries of 8 programs works the other no. Why is he doing this? Yes it is installed correctly. He is in the Arduino library. Those characters where I want to say? Matrix 8x32 works in reverse. Why? Max72xx test. Help the repair program. Thank you and have a nice day.
You need to tell the software the type of matrix hardware you are using. This is done in the sketch.
Healthy. Where do I define hardware tipe? What do I say? MAX7219CNG. Or the kind 1088AS. I have no experience yet. Help. Well thank you.
