I am using an esp32 cam as a soft access point and I would like to activate an LED when it begins streaming. I only want the light on when it is streaming. Is this possible and what can I use to trigger the output?
To activate an LED You need a free output pin, a resistor and the LED.
I have no problem activating the LED, I can use the GPIO and activate the light. I am trying to figure out what I can use as the trigger signal internally. What signal can I use when the stream begins and then turn off when the stream ends.
What code are you using to do the streaming?
the code that streams.
when the code that streams starts streaming, turn led on.
when code that streams is done doing the streaming thing, turn led off.
as per post 4, what code is being used that does the stream thing?
I am currently using the web server example code. I think that is what I am looking for is what signal can I trigger the output?
You are asking the forum for help... but you do not provide enough information. Post your code !
#include "esp_camera.h" #include <WiFi.h> // // WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality // Ensure ESP32 Wrover Module or other board with PSRAM is selected // Partial images will be transmitted if image exceeds buffer size // // Select camera model //#define CAMERA_MODEL_WROVER_KIT // Has PSRAM //#define CAMERA_MODEL_ESP_EYE // Has PSRAM //#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM //#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM //#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM //#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM #define CAMERA_MODEL_AI_THINKER // Has PSRAM //#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM #include "camera_pins.h" const char* ssid = "esp32"; //You can create any ssid and password you like const char* password = "1234"; void startCameraServer(); void setup() { Serial.begin(115200); Serial.setDebugOutput(true); Serial.println(); camera_config_t config; config.ledc_channel = LEDC_CHANNEL_0; config.ledc_timer = LEDC_TIMER_0; config.pin_d0 = Y2_GPIO_NUM; config.pin_d1 = Y3_GPIO_NUM; config.pin_d2 = Y4_GPIO_NUM; config.pin_d3 = Y5_GPIO_NUM; config.pin_d4 = Y6_GPIO_NUM; config.pin_d5 = Y7_GPIO_NUM; config.pin_d6 = Y8_GPIO_NUM; config.pin_d7 = Y9_GPIO_NUM; config.pin_xclk = XCLK_GPIO_NUM; config.pin_pclk = PCLK_GPIO_NUM; config.pin_vsync = VSYNC_GPIO_NUM; config.pin_href = HREF_GPIO_NUM; config.pin_sscb_sda = SIOD_GPIO_NUM; config.pin_sscb_scl = SIOC_GPIO_NUM; config.pin_pwdn = PWDN_GPIO_NUM; config.pin_reset = RESET_GPIO_NUM; config.xclk_freq_hz = 20000000; config.pixel_format = PIXFORMAT_JPEG; // if PSRAM IC present, init with UXGA resolution and higher JPEG quality // for larger pre-allocated frame buffer. if(psramFound()){ config.frame_size = FRAMESIZE_UXGA; config.jpeg_quality = 10; config.fb_count = 2; } else { config.frame_size = FRAMESIZE_SVGA; config.jpeg_quality = 12; config.fb_count = 1; } #if defined(CAMERA_MODEL_ESP_EYE) pinMode(13, INPUT_PULLUP); pinMode(14, INPUT_PULLUP); #endif // camera init pinMode(2, OUTPUT); //This is the output pin I am declaring for the lights esp_err_t err = esp_camera_init(&config); if (err != ESP_OK) { Serial.printf("Camera init failed with error 0x%x", err);} // return; else { digitalWrite(2, HIGH); } sensor_t * s = esp_camera_sensor_get(); // initial sensors are flipped vertically and colors are a bit saturated if (s->id.PID == OV3660_PID) { s->set_vflip(s, 0); // flip it back ALEX YOU CHANGED THIS SETTING FROM 1 TO 0 IF HAVING TROUBLE CHANGE IT BACK s->set_brightness(s, 1); // up the brightness just a bit s->set_saturation(s, -2); // lower the saturation } // drop down frame size for higher initial frame rate s->set_framesize(s, FRAMESIZE_QVGA); #if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM) s->set_vflip(s, 1); s->set_hmirror(s, 1); #endif WiFi.softAP(ssid, password); // These four lines are the ones that create the access point IPAddress IP = WiFi.softAPIP(); Serial.print("AP IP address: "); Serial.print(IP); startCameraServer(); Serial.print("Camera Ready! Use 'http://"); Serial.print(WiFi.localIP()); Serial.println("' to connect"); } void loop() { // put your main code here, to run repeatedly: delay(10000); }`Preformatted text`
You'll want to add the LED control at the appropriate place in the code for this function:
This code doesn't do anything, other than creating a WiFi access point and initialising the camera.
It doesn't take any photos or create any video stream... so turning on an LED is the least of your problems.
And reading the forum instructions and editing (not repeating) #8 to properly post your code would be good.
The OP's code does not even take images. I'll post some code that takes images and ftp's those images, streams. The OP may or not find something useful.
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include "certs.h"
#include "soc/soc.h" // Disable brownout problems
#include "soc/rtc_cntl_reg.h" // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
#include <PubSubClient.h>
#include <ESP32Time.h>
WiFiClient wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
ESP32Time rtc;
//#define evtDoMQTTParse ( 1 << 0 ) // declare an event
//EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 300;
struct stu_message
char payload [payloadSize] = {'\0'};
String topic ;
} x_message;
int mqttOK = 0;
bool TimeSet = false;
bool FlashMode = false;
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
log_i("Connected to WiFi access point");
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
// clear locations
memset( x_message.payload, '\0', payloadSize );
x_message.topic = ""; //clear string buffer
x_message.topic.concat( topic );
int i = 0;
for ( i; i < length; i++)
x_message.payload[i] = ((char)payload[i]);
x_message.payload[i] = '\0';
xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
pinMode( GPIO_NUM_4, OUTPUT);
digitalWrite( GPIO_NUM_4, LOW);
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
//eg = xEventGroupCreate(); // get an event group handle
x_message.topic.reserve( payloadSize );
xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
sema_mqttOK = xSemaphoreCreateBinary();
xSemaphoreGive( sema_mqttOK );
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 9000, NULL, 4, NULL, 1 ); // assign all to core 1, WiFi in use.
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
if ( configInitCamera() )
log_i(" start camera task" );
xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 60000, NULL, 6, NULL, 1 );
log_i( " camera failed to initilize, rebooting in 5." );
vTaskDelay( 2000 );
ESP.restart();
} // void setup()
void capturePhoto_sendFTP( void *pvParameters )
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 1000 * 5; //delay for mS
//!!!!!Must wait for MQTT connection and proper setup of the sema_MQTT_KeepAlive!!!!
while ( !MQTTclient.connected() )
vTaskDelay( 500 );
for (;;)
log_i( "tick");
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
camera_fb_t * fb = NULL; // pointer
fb = esp_camera_fb_get();
if (!fb)
log_i( "Camera capture failed" );
esp_camera_fb_return(fb);
} else
ftp.OpenConnection(); // try open FTP
if ( ftp.isConnected() )
//try send file ftp
ftp.ChangeWorkDir( ftp_path );
ftp.DeleteFile( ftp_file_name );
ftp.InitFile( ftp_file_type ); //"Type I"
ftp.NewFile( ftp_file_name );
ftp.WriteData( (unsigned char *)fb->buf, fb->len );
ftp.CloseFile();
ftp.CloseConnection();
esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
xSemaphoreGive( sema_MQTT_KeepAlive );
vTaskDelayUntil( &xLastWakeTime, xFrequency );
vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
void configureCameraSettings_grpE( int _lenC, int _Hmirror, int _Vflip, int _dcw, int _colorbar )
s->set_lenc(s, _lenC); // 0 = disable , 1 = enable
s->set_hmirror(s, _Hmirror); // 0 = disable , 1 = enable
s->set_vflip(s, _Vflip); // 0 = disable , 1 = enable
s->set_dcw(s, _dcw); // 0 = disable , 1 = enable
////s->set_colorbar(s, _colorbar); // 0 = disable , 1 = enable
void configureCameraSettings_grpD( int _gc, int _agc, int _celing, int _bpc, int _wpc, int _gma )
s->set_gain_ctrl(s, _gc); // 0 = disable , 1 = enable
s->set_agc_gain(s, _agc); // 0 to 30
s->set_gainceiling(s, (gainceiling_t)_celing); // 0 to 6
s->set_bpc(s, _bpc); // 0 = disable , 1 = enable
s->set_wpc(s, _wpc); // 0 = disable , 1 = enable
s->set_raw_gma(s, _gma); // 0 = disable , 1 = enable
void configureCameraSettings_grpC( int _exctl, int _aec2, int _ae, int _aec )
s->set_exposure_ctrl(s, _exctl); // 0 = disable , 1 = enable
s->set_aec2(s, _aec2); // 0 = disable , 1 = enable
s->set_ae_level(s, _ae); // -2 to 2
////s->set_aec_value(s, _aec); // 0 to 1200 CAUSES BLACK IMAGE????
void configureCameraSettings_grpB( int se, int wb, int awb, int wbmode )
s->set_special_effect(s, se); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
s->set_whitebal(s, wb); // 0 = disable , 1 = enable
s->set_awb_gain(s, awb); // 0 = disable , 1 = enable
s->set_wb_mode(s, wbmode); // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
void configureCameraSettings_grpA(int brightness, int contrast, int saturation )
if ( ((brightness > -3) && (brightness < 3)) && ((contrast > -3) && (contrast < 3)) && ((saturation > -3) && (saturation < 3)) )
s->set_brightness( s, brightness ); // -2 to 2
s->set_contrast( s, contrast ); // -2 to 2
s->set_saturation( s, saturation ); // -2 to 2
} //void configureCameraSettings()
sensor_t * s = esp_camera_sensor_get(); //see certs.h for more info
s->set_brightness(s, -1); // -2 to 2 **************************
s->set_contrast(s, 0); // -2 to 2
s->set_saturation(s, 0); // -2 to 2
s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
s->set_whitebal(s, 1); // 0 = disable , 1 = enable
s->set_awb_gain(s, 1); // 0 = disable , 1 = enable
s->set_wb_mode(s, 0); // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
s->set_exposure_ctrl(s, 1); // 0 = disable , 1 = enable
s->set_aec2(s, 0); // 0 = disable , 1 = enable
s->set_ae_level(s, 0); // -2 to 2
s->set_aec_value(s, 300); // 0 to 1200
s->set_gain_ctrl(s, 1); // 0 = disable , 1 = enable
s->set_agc_gain(s, 0); // 0 to 30
s->set_gainceiling(s, (gainceiling_t)0); // 0 to 6
s->set_bpc(s, 0); // 0 = disable , 1 = enable
s->set_wpc(s, 1); // 0 = disable , 1 = enable
s->set_raw_gma(s, 1); // 0 = disable , 1 = enable
s->set_lenc(s, 1); // 0 = disable , 1 = enable
s->set_hmirror(s, 0); // 0 = disable , 1 = enable
s->set_vflip(s, 0); // 0 = disable , 1 = enable
s->set_dcw(s, 1); // 0 = disable , 1 = enable
s->set_colorbar(s, 0); // 0 = disable , 1 = enable
bool configInitCamera()
camera_config_t config = {}; // Stores the camera configuration parameters
config.pin_d0 = GPIO_NUM_5; //Y2
config.pin_d1 = GPIO_NUM_18; //Y3
config.pin_d2 = GPIO_NUM_19; //Y4
config.pin_d3 = GPIO_NUM_21; //Y5
config.pin_d4 = GPIO_NUM_36; //Y6
config.pin_d5 = GPIO_NUM_39; //Y7
config.pin_d6 = GPIO_NUM_34; //Y8
config.pin_d7 = GPIO_NUM_35; // Y9
config.pin_xclk = GPIO_NUM_0; //XCLK
config.pin_pclk = GPIO_NUM_22; //PCLK
config.pin_vsync = GPIO_NUM_25; //VSSYNC
config.pin_href = GPIO_NUM_23; // HREF
config.pin_sscb_sda = GPIO_NUM_26; //SIOD
config.pin_sscb_scl = GPIO_NUM_27; //SIOC
config.pin_pwdn = GPIO_NUM_32; //PWDN
config.pin_reset = -1; //RESET
config.pixel_format = PIXFORMAT_JPEG; ////YUV422,GRAYSCALE,RGB565,JPEG
config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
FRAMESIZE_UXGA (1600 x 1200)
FRAMESIZE_QVGA (320 x 240)
FRAMESIZE_CIF (352 x 288)
FRAMESIZE_VGA (640 x 480)
FRAMESIZE_SVGA (800 x 600)
FRAMESIZE_XGA (1024 x 768)
FRAMESIZE_SXGA (1280 x 1024)
config.jpeg_quality = 10; //0-63 lower number means higher quality
* The image quality (jpeg_quality) can be a number between 0 and 63.
* A lower number means a higher quality.
* However, very low numbers for image quality,
* specially at higher resolution can make the ESP32-CAM to crash or it may not be able to take the photos properly.
* So, if you notice that the images taken with the ESP32-CAM are cut in half, or with strange colors,
* that’s probably a sign that you need to lower the quality (select a higher number).
// Initialize the Camera
log_i("Camera init failed with error %d", err );
return false;
configureCameraSettings();
return true;
} //void configInitCamera()
void connectToWiFi()
int TryCount = 0;
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 2500 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
const TickType_t xFrequency = 250; //delay for ms
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // !!!!!whiles MQTTlient.loop() is running no other mqtt operations should be in process!!!!!
MQTTclient.loop();
else {
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelete ( NULL );
void connectToMQTT()
byte mac[5]; // create client ID from mac address
WiFi.macAddress(mac); // get mac address
String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
vTaskDelay( 250 );
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( topicOK );
MQTTclient.subscribe( topicGrpA );
MQTTclient.subscribe( topicGrpB );
MQTTclient.subscribe( topicGrpC );
MQTTclient.subscribe( topicGrpD );
MQTTclient.subscribe( topicGrpE );
MQTTclient.subscribe( topicFlash );
} //void connectToMQTT()
void fmqttWatchDog( void * paramater )
int UpdateImeTrigger = 86400; //seconds in a day
int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
int maxNonMQTTresponse = 3;
const TickType_t xFrequency = 60000; //delay for mS
for (;;)
xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
mqttOK++;
if ( mqttOK >= maxNonMQTTresponse )
log_i( "mqtt watchdog rest" );
vTaskDelay( 200 );
ESP.restart();
UpdateTimeInterval++; // trigger new time get
if ( UpdateTimeInterval >= UpdateImeTrigger )
TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fparseMQTT( void *pvParameters )
struct stu_message px_message;
for (;;)
if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
mqttOK = 0;
if ( !TimeSet)
if ( String(px_message.topic) == topicOK )
String temp = "";
temp = px_message.payload[0];
temp += px_message.payload[1];
temp += px_message.payload[2];
temp += px_message.payload[3];
int year = temp.toInt();
temp = "";
temp = px_message.payload[5];
temp += px_message.payload[6];
int month = temp.toInt();
temp = "";
temp = px_message.payload[8];
temp += px_message.payload[9];
int day = temp.toInt();
temp = "";
temp = px_message.payload[11];
temp += px_message.payload[12];
int hour = temp.toInt();
temp = "";
temp = px_message.payload[14];
temp += px_message.payload[15];
int min = temp.toInt();
rtc.setTime( 0, min, hour, day, month, year );
log_i( "%s rtc %s ", px_message.payload, rtc.getTime() );
TimeSet = true;
if ( String(px_message.topic) == topicGrpA )
//finding first letter
String sTmp = String( px_message.payload );
int commaIndex = sTmp.indexOf(',');
if ( sTmp.substring(0, commaIndex) == "a" );
int brt = (sTmp.substring(0, commaIndex)).toInt();
sTmp.remove( 0, (commaIndex + 1) );
int ctrast = (sTmp.substring(0, commaIndex)).toInt();
sTmp.remove( 0, (commaIndex + 1) ); // chop off begining of message
int sat = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpA( brt, ctrast, sat );
if ( String(px_message.topic) == topicGrpB )
if ( sTmp.substring(0, commaIndex) == "b" );
int se = (sTmp.substring(0, commaIndex)).toInt();
int wbb = (sTmp.substring(0, commaIndex)).toInt();
int wba = (sTmp.substring(0, commaIndex)).toInt();
int wbm = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpB( se, wbb, wba, wbm );
if ( String(px_message.topic) == topicGrpC )
if ( sTmp.substring(0, commaIndex) == "c" );
int ex = (sTmp.substring(0, commaIndex)).toInt();
int aec2 = (sTmp.substring(0, commaIndex)).toInt();
int ae = (sTmp.substring(0, commaIndex)).toInt();
int aec = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpC( ex, aec2, ae, aec );
if ( String(px_message.topic) == topicGrpD )
if ( sTmp.substring(0, commaIndex) == "d" );
int gc = (sTmp.substring(0, commaIndex)).toInt();
int agc = (sTmp.substring(0, commaIndex)).toInt();
int celing = (sTmp.substring(0, commaIndex)).toInt();
int bpc = (sTmp.substring(0, commaIndex)).toInt();
int wpc = (sTmp.substring(0, commaIndex)).toInt();
int gma = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpD( gc, agc, celing, bpc, wpc, gma );
if ( String(px_message.topic) == topicGrpE )
if ( sTmp.substring(0, commaIndex) == "e" );
int lenC = (sTmp.substring(0, commaIndex)).toInt();
int Hmirror = (sTmp.substring(0, commaIndex)).toInt();
int Vflip = (sTmp.substring(0, commaIndex)).toInt();
int dcw = (sTmp.substring(0, commaIndex)).toInt();
int colorbar = (sTmp.substring(0, commaIndex)).toInt();
configureCameraSettings_grpE( lenC, Hmirror, Vflip, dcw, colorbar );
if ( String(px_message.topic) == topicFlash )
FlashMode = bool(px_message.payload);
} //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
} //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
Good luck.
It launches startCameraServer(), which is all it needs to do.
try this you can turn flasher on when you need it..
camera live feed stream using websockets.
if you want to change quality of streaming please change it from arduino code.
I'm still developing webpage.
#include <WiFi.h>
#include <WebSocketsServer.h>
#include <WebServer.h>
#include <ArduinoJson.h>
#include <Arduino.h>
const char camhtml [] PROGMEM =
R"=====(
<!DOCTYPE HTML>
<html>
<head>
<meta charset="UTF-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>WiFi CAM</title>
<style>
margin: 0;
padding: 0;
box-sizing: border-box;
body{
background-color: black;
header{
display: flex;
justify-content: center;
align-items: center;
padding: 2%;
#live{
max-width: 90vw;
max-height: 90vh;
border: 8px solid white;
.cam{
display: flex;
h2{
font-family: Arial, Helvetica, sans-serif;
color: white;
text-align: center;
margin-top: 5px;
#cam_led{
width: 45px;
height: 45px;
color: blue;
font-weight: 800;
font-size: 16;
background-color: white;
border: 2px solid blue;
border-radius: 20%;
margin: auto;
#cam_led:active{
color: white;
background-color: blue;
#cam_on{
width: 50vw;
height: 45px;
font-family: 'Times New Roman', Times, serif;
font-size: medium;
font-weight: bolder;
color: white;
background-color: rgb(0, 0, 0);
border: 2px solid white;
border-radius: 10px;
margin: auto;
#cam_on:active{
background-color: red;
border: 2px solid red;
.resf{
margin: auto;
#res{
appearance: none;
background-color: gray;
border: 2px solid rgb(255, 255, 255);
color: white;
font-size: medium;
text-align: center;
border-radius: 5px;
padding: 5px;
#res:active{
#res option{
font-weight: bold;
color: black;
background-color: rgba(255, 255, 255, 0.479);
</style>
</head>
<header>
<form class="resf">
<select id="res">
<option value="FRAMESIZE_QQVGA">QQVGA [160x120]</option>
<option value="FRAMESIZE_HQVGA">HQVGA [240x176]</option>
<option value="FRAMESIZE_QVGA">QVGA [320x240]</option>
<option value="FRAMESIZE_CIF" selected>CIF [400x296]</option>
<option value="FRAMESIZE_VGA">VGA [640x480]</option>
<option value="FRAMESIZE_SVGA">SVGA [800x600]</option>
<option value="FRAMESIZE_XGA">XGA [1024x768]</option>
<option value="FRAMESIZE_SXGA">SXGA [1280x1024]</option>
<option value="FRAMESIZE_UXGA">UXGA [1600x1200]</option>
</select>
</form>
<button id="cam_on" onclick="camon()">| | WiFi CAM | |</button>
<button id="cam_led" onclick="ledon()">LED</button>
</header>
<body>
<div class="cam">
<img id='live' src=''>
</div>
</body>
<script>
var wsc;
function connect_websocket(){
wsc = new WebSocket('ws://'+ window.location.hostname + ':81/', ['arduino']);
wsc.onopen = function(){
wsc.send('connect' + new Date());
wsc.onerror = function(error){
console.log('WebSocket Error', error);
//alert('WebSocket Error', error);
wsc.binaryType = 'arraybuffer';
wsc.onmessage = function (msg){
var bytes = new Uint8Array(msg.data);
var binary= '';
var len = bytes.byteLength;
for (var i = 0; i < len; i++) {
binary += String.fromCharCode(bytes[i])
var img = document.getElementById('live');
img.src = 'data:image/jpg;base64,'+window.btoa(binary);
wsc.onclose = function(){
// alert('The connection has been closed.');
connect_websocket();
var res = document.getElementById("res");
res.addEventListener("input",function (){
console.log(this.value);
wsc.send(JSON.stringify({"T":"res","res":this.value}));
var led = false;
function ledon(){
led =! led;
console.log("flasher = " + led);
wsc.send(JSON.stringify({"T":"led","led":led}));
var cam = false;
function camon(){
cam =! cam;
console.log("cam = " + cam);
wsc.send(JSON.stringify({"T":"cam","cam":cam}));
</script>
</html>
#define i_led 4
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
WebSocketsServer webSocket = WebSocketsServer(81);
WebServer server(80);
uint8_t cam_num;
bool ws_on = false;
bool cam_on = false;
bool led = false;
framesize_t res = FRAMESIZE_VGA;
//wifi//
const char* ssid = "ssid";
const char* password = "password";
StaticJsonDocument<200> doc_rx;
void configCamera(){
config.frame_size = res;
config.fb_count = 3;
return;
void liveCam(uint8_t num){
//capture a frame
camera_fb_t * fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Frame buffer could not be acquired");
return;
//replace this with your own function
webSocket.sendBIN(num, fb->buf, fb->len);
//return the frame buffer back to be reused
void WiFi_Recived_data(){
String type = doc_rx["T"];
if(type == "cam"){cam_on = doc_rx["cam"];}
if(type == "led"){led = doc_rx["led"];}
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[%u] Disconnected!\n", num);
ws_on = false;
case WStype_CONNECTED:
Serial.println("Client " + String(num) + " connected");
cam_num = num;
ws_on = true;
case WStype_TEXT:
Serial.printf("[%u]-- %s\n", num, payload);
DeserializationError error = deserializeJson(doc_rx, payload);
if(error){
Serial.print(F("deserializeJason() failed: "));
Serial.println(error.f_str());
return;
else{
WiFi_Recived_data();
void flasher(){
if(led == true && ws_on == true){
digitalWrite(i_led,1);
if(led == false || ws_on == false){
digitalWrite(i_led,0);
void handle_onConnect(){
server.send(200, "text/html", camhtml);
void srv_handle_not_found (){
server.send(404, "text/plain", "File not Found");
pinMode(i_led,OUTPUT);
configCamera();
WiFi.begin(ssid, password);
Serial.println("Establishing connection to WiFi with SSID: " + String(ssid));
Serial.println("");
delay(450);
Serial.print(".");
delay(50);
Serial.println("");
Serial.print("Connected to network with IP address: ");
/* Serial.print("Configuring access point...");
IPAddress myIP = WiFi.softAPIP();
Serial.println(myIP);*/
webSocket.begin();
webSocket.onEvent(webSocketEvent);
Serial.println("Web Server in SETUP");
server.on("/", handle_onConnect);
server.onNotFound(srv_handle_not_found);
server.begin();
Serial.println("server started successfuly");
server.handleClient();
webSocket.loop();
flasher();
if(cam_on == true && ws_on == true){
liveCam(cam_num);
Well, that didn't work, did it?
Perchance read the instructions for posting code and edit it.
sorry for late and unformatted typing....
but it works for me..
