I want to connect sketching and sketching.
It does not work when I put it between simply.
Please tell me the connection of the sketching of A/B.
sketch A
#include <Servo.h>
Servo myservo;
int pos = 0;
myservo.attach( 2 );
for ( pos = 0; pos < 180; pos += 1 ) {
myservo.write( pos );
delay( 15 );
for ( pos = 180; pos > 0; pos -= 1 ) {
delay( 15 );
sketch B
int tonePin = 4; //Tone - Red Jumper
int trigPin = 9; //Trig - violet Jumper
int echoPin = 10; //Echo - yellow Jumper
int clockPin = 11; //IC Pin 11 - white Jumper
int latchPin = 12; //IC Pin 12 - Blue Jumper
int dataPin = 13; //IC Pin 14 - Green Jumper
byte possible_patterns[9] = {
B00000000,
B00000001,
B00000011,
B00000111,
B00001111,
B00011111,
B00111111,
B01111111,
B11111111,
int proximity=0;
int duration;
int distance;
//Serial Port
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(clockPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(tonePin, OUTPUT);
digitalWrite(latchPin, LOW);
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
/if (distance >= 45 || distance <= 0){
Serial.println(“Out of range”);
else {
Serial.print(distance);
Serial.println(" cm");
proximity=map(distance, 0, 45, 8, 0);
//Serial.println(proximity);
if (proximity <= 0){
proximity=0;
else if (proximity >= 3 && proximity <= 4){
tone(tonePin, 200000, 200);
else if (proximity >= 5 && proximity <= 6){
tone(tonePin,5000, 200);
else if (proximity >= 7 && proximity <= 8){
tone(tonePin, 1000, 200);
shiftOut(dataPin, clockPin, MSBFIRST, possible_patterns[proximity]);
digitalWrite(latchPin, HIGH);
delay(600);
noTone(tonePin);
