This is my first dot matrix work using ESP32, and I am not sure of the difference between Arduino code and ESP32 code. I would like to know how to write the ESP32 code using the Arduino code here as an example and the difference between the two.
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <avr/io.h>
int A = 2;
int B = 3;
int C = 4;
int D = 5;
int Data_Red = 6;
int Data_Green = 7;
int Clk = 8;
int LE = 9;
int OE = 10;
const int __attribute__((progmem)) string[][16]={
0x00,0x00,0x380,0x380,0x6c0,0x6c0,0x6c0,0xc60,0xc60,0xfe0,0x1830,0x1830,0x1830,0x00,0x00,0x00, //A
0x00,0x00,0x7f0,0xc30,0xc30,0xc30,0x630,0x7f0,0xc30,0x1830,0x1830,0xc30,0x7f0,0x00,0x00,0x00, //B
0x00,0x00,0x7c0,0xc60,0x1830,0x30,0x30,0x30,0x30,0x30,0x1830,0xc60,0x7c0,0x00,0x00,0x00, //C
0x00,0x00,0x3f0,0x630,0xc30,0x1830,0x1830,0x1830,0x1830,0x1830,0xc30,0x630,0x3f0,0x00,0x00,0x00, //D
0x00,0x00,0xff0,0x30,0x30,0x30,0x30,0x7f0,0x30,0x30,0x30,0x30,0xff0,0x00,0x00,0x00, //E
0x00,0x00,0xff0,0x30,0x30,0x30,0x30,0x7f0,0x30,0x30,0x30,0x30,0x30,0x00,0x00,0x00, //F
0x00,0x00,0xf80,0x18c0,0x3060,0x30,0x30,0x3e30,0x3030,0x3030,0x3060,0x38c0,0x3f80,0x00,0x00,0x00, //G
0x00,0x00,0x1830,0x1830,0x1830,0x1830,0x1830,0x1ff0,0x1830,0x1830,0x1830,0x1830,0x1830,0x00,0x00,0x00, //H
0x00,0x00,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x00,0x00,0x00, //I
0x00,0x00,0x180,0x180,0x180,0x180,0x180,0x180,0x180,0x180,0x198,0x198,0xf0,0x00,0x00,0x00, //J
0x00,0x00,0xc30,0x630,0x330,0x1b0,0xf0,0x1f0,0x330,0x330,0x630,0xc30,0xc30,0x00,0x00,0x00, //K
0x00,0x00,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0xff0,0x00,0x00,0x00, //L
0x00,0x00,0x3018,0x3018,0x3838,0x3838,0x3c78,0x3c78,0x36d8,0x36d8,0x3398,0x3398,0x3018,0x00,0x00,0x00, //M
0x00,0x00,0xc30,0xc70,0xc70,0xcf0,0xcf0,0xdb0,0xdb0,0xf30,0xf30,0xe30,0xe30,0x00,0x00,0x00, //N
0x00,0x00,0x7c0,0xc60,0x1830,0x3018,0x3018,0x3018,0x3018,0x3018,0x1830,0xc60,0x7c0,0x00,0x00,0x00, //O
0x00,0x00,0x7f0,0xc30,0x1830,0x1830,0xc30,0x7f0,0x30,0x30,0x30,0x30,0x30,0x00,0x00,0x00, //P
0x00,0x00,0x7c0,0xc60,0x1830,0x3018,0x3018,0x3018,0x3018,0x3318,0x1e30,0xc60,0x1fc0,0x00,0x00,0x00, //Q
0x00,0x00,0x7f0,0xc30,0x1830,0x1830,0xc30,0x7f0,0xc30,0x1830,0x1830,0x1830,0x1830,0x00,0x00,0x00, //R
0x00,0x00,0x7c0,0xc60,0x1830,0x30,0xe0,0x780,0xc00,0x1800,0x1830,0xc60,0x7c0,0x00,0x00,0x00, //S
0x00,0x00,0xff0,0x180,0x180,0x180,0x180,0x180,0x180,0x180,0x180,0x180,0x180,0x00,0x00,0x00, //T
0x00,0x00,0x1830,0x1830,0x1830,0x1830,0x1830,0x1830,0x1830,0x1830,0x1830,0xc60,0x7c0,0x00,0x00,0x00, //U
0x00,0x00,0xc30,0xc30,0xc30,0x660,0x660,0x660,0x3c0,0x3c0,0x3c0,0x180,0x180,0x00,0x00,0x00, //V
0x00,0x00,0x6186,0x6186,0x6186,0x33cc,0x33cc,0x33cc,0x1e78,0x1e78,0x1e78,0xc30,0xc30,0x00,0x00,0x00, //W
0x00,0x00,0xc30,0xc30,0x660,0x660,0x3c0,0x180,0x3c0,0x660,0x660,0xc30,0xc30,0x00,0x00,0x00, //X
0x00,0x00,0xc30,0xc30,0x660,0x660,0x3c0,0x180,0x180,0x180,0x180,0x180,0x180,0x00,0x00,0x00, //Y
0x00,0x00,0xff0,0xc00,0x600,0x300,0x300,0x180,0xc0,0xc0,0x60,0x30,0xff0,0x00,0x00,0x00, //Z
unsigned char Dot_char_cnt=0;
unsigned char flag_cnt=0;
unsigned char move_motion=0;
unsigned int Move_cnt=16;
unsigned int Move_cnt2=0;
unsigned int up_cnt=0;
unsigned int up_cnt2=16;
unsigned int str_speed_cnt=0;
bool flag_Oe=0;
ISR(TIMER2_OVF_vect){
static bool output = HIGH;
digitalWrite(1, output);
output = !output;
static unsigned int string_moving_speed_value=500;
static unsigned int cnt=0;
if(flag_Oe)
digitalWrite(OE, LOW);
cnt++;
if(cnt>=5)
flag_Oe=0;
cnt=0;
digitalWrite(OE, HIGH);
str_speed_cnt++;
if(str_speed_cnt>string_moving_speed_value)
str_speed_cnt=0;
up_cnt2--;
up_cnt++;
if(up_cnt2==0||up_cnt==16){
up_cnt2=16;
up_cnt=0;
move_motion++;
if(move_motion>1){
move_motion=0;
Dot_char_cnt+=2;
flag_cnt++;
if(flag_cnt==3)
flag_cnt=0;
TCNT2=0xe7;
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(Data_Red, OUTPUT);
pinMode(Data_Green, OUTPUT);
pinMode(Clk, OUTPUT);
pinMode(LE, OUTPUT);
pinMode(OE, OUTPUT);
pinMode(1, OUTPUT);
TCCR2A=0x00;
TCCR2B=0x04;
TIMSK2=0x01;
TCNT2=0xe7;
SREG=0x80;
void row_dynamic()
static unsigned int str_cnt=0;
switch(str_cnt)//ROW SHIFT!
case 0:digitalWrite(A, LOW); digitalWrite(B, LOW); digitalWrite(C, LOW); digitalWrite(D, LOW); break; //1행 LED
case 1:digitalWrite(A, HIGH); digitalWrite(B, LOW); digitalWrite(C, LOW); digitalWrite(D, LOW); break; //2행 LED
case 2:digitalWrite(A, LOW); digitalWrite(B, HIGH); digitalWrite(C, LOW); digitalWrite(D, LOW); break; //3행 LED
case 3:digitalWrite(A, HIGH); digitalWrite(B, HIGH); digitalWrite(C, LOW); digitalWrite(D, LOW); break; //4행 LED
case 4:digitalWrite(A, LOW); digitalWrite(B, LOW); digitalWrite(C, HIGH); digitalWrite(D, LOW); break; //5행 LED
case 5:digitalWrite(A, HIGH); digitalWrite(B, LOW); digitalWrite(C, HIGH); digitalWrite(D, LOW); break; //6행 LED
case 6:digitalWrite(A, LOW); digitalWrite(B, HIGH); digitalWrite(C, HIGH); digitalWrite(D, LOW); break; //7행 LED
case 7:digitalWrite(A, HIGH); digitalWrite(B, HIGH); digitalWrite(C, HIGH); digitalWrite(D, LOW); break; //8행 LED
case 8:digitalWrite(A, LOW); digitalWrite(B, LOW); digitalWrite(C, LOW); digitalWrite(D, HIGH); break; //9행 LED
case 9:digitalWrite(A, HIGH); digitalWrite(B, LOW); digitalWrite(C, LOW); digitalWrite(D, HIGH); break; //10행 LED
case 10:digitalWrite(A, LOW); digitalWrite(B, HIGH); digitalWrite(C, LOW); digitalWrite(D, HIGH); break; //11행 LED
case 11:digitalWrite(A, HIGH); digitalWrite(B, HIGH); digitalWrite(C, LOW); digitalWrite(D, HIGH); break; //12행 LED
case 12:digitalWrite(A, LOW); digitalWrite(B, LOW); digitalWrite(C, HIGH); digitalWrite(D, HIGH); break; //13행 LED
case 13:digitalWrite(A, HIGH); digitalWrite(B, LOW); digitalWrite(C, HIGH); digitalWrite(D, HIGH); break; //14행 LED
case 14:digitalWrite(A, LOW); digitalWrite(B, HIGH); digitalWrite(C, HIGH); digitalWrite(D, HIGH); break; //15행 LED
case 15:digitalWrite(A, HIGH); digitalWrite(B, HIGH); digitalWrite(C, HIGH); digitalWrite(D, HIGH); break; //16행 LED
str_cnt++;
if(str_cnt==16)
str_cnt=0;
void shift_Register(unsigned char out)
unsigned char clk=0;
for(clk=0;clk<8;clk++){
if(out&(0x80>>clk))
switch(flag_cnt){
case 0:digitalWrite(Data_Green, LOW);digitalWrite(Data_Red, HIGH);break; //Red
case 1:digitalWrite(Data_Green, HIGH);digitalWrite(Data_Red, LOW);break; //Green
case 2:digitalWrite(Data_Green, HIGH);digitalWrite(Data_Red, HIGH);break; //Orange
digitalWrite(Data_Green, LOW);digitalWrite(Data_Red, LOW);
digitalWrite(Clk, HIGH);
digitalWrite(Clk, LOW);
void ActivePulse()
digitalWrite(LE, HIGH);
digitalWrite(LE, LOW);
flag_Oe=1;
void dot1_display_shift(unsigned char first,unsigned char second)
static unsigned int i_cnt=0;
unsigned int buff1[16]={0}; //Dot1
unsigned int buff2[16]={0}; //Dot2
unsigned char high1=0; //Dot1
unsigned char low1=0; //Dot1
unsigned char high2=0; //Dot2
unsigned char low2=0; //Dot2
register unsigned int i=0;
for(i_cnt=0;i_cnt<16;i_cnt++){
if(move_motion==0)
buff1[i_cnt]=pgm_read_word(&string[first][i_cnt]); // 1st String Dot1 stop
buff2[i_cnt]=pgm_read_word(&string[second][i_cnt]); // 2st String Dot2 stop
if(move_motion==1)
if(i_cnt+up_cnt2>15)
buff1[i_cnt]=pgm_read_word(&string[first][i_cnt+up_cnt2-16]); // 1st String Dot1 out
buff2[i_cnt]=pgm_read_word(&string[second][i_cnt+up_cnt2-16]); // 2st String Dot2 out
buff1[i_cnt]=pgm_read_word(&string[first+2][i_cnt+up_cnt2]); // 1st String Dot1 in
buff2[i_cnt]=pgm_read_word(&string[second+2][i_cnt+up_cnt2]); // 2st String Dot2 in
for(i=0;i<16;i++)
high1=(buff1[i]>>8);
low1=(buff1[i]&0xff);
high2=(buff2[i]>>8);
low2=(buff2[i]&0xff);
shift_Register(low1);
shift_Register(high1);
shift_Register(low2);
shift_Register(high2);
row_dynamic();
ActivePulse();
dot1_display_shift(Dot_char_cnt,Dot_char_cnt+1);
if(Dot_char_cnt==26){
Dot_char_cnt=0;
