I want to convert String to uint16_t for irsend.sendRaw
I want to convert string onn to uint16_t which I am using the rawdata from IR remote and the code like this which I want to use z in the irsend I tried it like this way but didn't work:
uint16_t onn30 [227] = {2980, 1802,  448, 1102,  394, 1134,  418, 408,  418, 410,  418, 434,  392, 1156,  448, 380,  392, 448,  394, 1156,  420, 1130,  394, 410,  418, 1158,  392, 434,  420, 406,  394, 1156,  394, 1172,  448, 356,  416, 1156,  394, 1158,  394, 434,  392, 434,  394, 1158,  392, 434,  394, 450,  392, 1156,  394, 434,  394, 434,  392, 408,  418, 434,  392, 434,  394, 410,  418, 448,  394, 434,  394, 410,  416, 410,  418, 434,  392, 434,  394, 434,  394, 434,  392, 448,  392, 434,  392, 434,  394, 1156,  392, 434,  392, 434,  394, 1158,  392, 434,  394, 448,  394, 1158,  392, 1158,  394, 434,  392, 434,  392, 436,  418, 408,  392, 434,  392, 450,  392, 410,  418, 434,  394, 410,  416, 436,  392, 408,  442, 410,  392, 434,  392, 448,  394, 434,  394, 434,  392, 434,  394, 434,  392, 434,  394, 410,  416, 1134,  416, 448,  394, 434,  392, 436,  392, 434,  392, 434,  394, 410,  416, 434,  392, 434,  420, 422,  392, 434,  392, 434,  394, 434,  394, 434,  394, 432,  418, 408,  394, 434,  394, 426,  416, 434,  418, 384,  418, 434,  394, 434,  392, 434,  418, 384,  416, 434,  394, 448,  394, 434,  394, 432,  394, 434,  394, 434,  392, 434,  394, 410,  444, 408,  394, 448,  394, 434,  418, 410,  392, 1158,  418, 1130,  394, 1158,  394, 1156,  448, 1104,  392, 428,  416};  // UNKNOWN F0A17D53
 uint16_t onn27 [227] = {2980, 1776,  420, 1156,  394, 1158,  392, 434,  396, 408,  418, 432,  394, 1156,  394, 434,  394, 448,  394, 1132,  420, 1134,  416, 434,  448, 1102,  394, 410,  418, 432,  394, 1132,  418, 1170,  394, 432,  394, 1156,  394, 1156,  394, 432,  420, 408,  394, 1156,  420, 408,  394, 448,  448, 1102,  394, 432,  394, 432,  394, 434,  394, 432,  394, 434,  450, 354,  418, 448,  394, 434,  394, 432,  394, 434,  394, 410,  442, 408,  394, 434,  394, 434,  420, 422,  394, 410,  442, 384,  418, 1158,  394, 434,  394, 434,  418, 1108,  418, 434,  394, 448,  394, 1132,  418, 1158,  394, 432,  394, 410,  418, 434,  394, 432,  396, 432,  394, 448,  394, 434,  394, 434,  394, 1158,  392, 434,  392, 434,  394, 434,  418, 384,  418, 448,  394, 434,  392, 434,  394, 410,  418, 434,  446, 356,  418, 434,  418, 1132,  394, 448,  394, 410,  418, 432,  394, 410,  418, 432,  420, 408,  420, 408,  394, 434,  392, 448,  394, 432,  394, 434,  394, 434,  446, 380,  394, 432,  394, 432,  394, 434,  448, 392,  392, 434,  394, 432,  394, 432,  418, 410,  394, 432,  394, 410,  416, 434,  418, 424,  392, 410,  442, 408,  394, 434,  392, 432,  448, 378,  394, 432,  448, 380,  394, 448,  394, 432,  420, 408,  394, 432,  394, 434,  394, 432,  394, 434,  394, 432,  448, 1120,  394};  // UNKNOWN 1794BB83
x = "onn";
y = 30;
z = x+y;
 //Serial.println(z); which z should print like onn30 or onn27 depends on the setpoint
 irsend.sendRaw( z, 227, 38);
but gave me error: no matching function for call to 'IRsend::sendRaw(String&, int, int)'
How can i convert "onn" String into uint16 ?
Thanks for all
At run time, variables have addresses, not names. You will not be able to add two values together to construct a name, and have that name directly relate to a memory address where the data is stored.
Why do you think you need to do that? There are almost certainly other ways.
Thanks PaulS for reply :slight_smile:
Actually I have around 30 rawdata for my AC control which i name them like this: onn31, onn30, onn29 and so on for alll rawdata . and I want to create only one irsend.sendRaw(z, 227, 38); which can choose any rawdata upon the setpoint I gave it 31,30,29.... and add it beside onn then will choose the rawdata depends on setpoint.
like this I want it. but irsend.sendRaw(z, 227, 38); only except uint16 not normal string! thats why I am thinking to convert it to uint16
Any Idea for this :slight_smile:
You can make a 2D array, of type uint16_t. Then, to send one IR code, you just need to specify the array index to use.
I did like this :
String onn = "onn";
 uint16_t x = strtoul(&(onn.c_str()[3]), NULL, 0);
 uint16_t y;
 uint16_t z;
 y = setpoint2;
 z = x+y;
but gave me this error : invalid conversion from 'uint16_t {aka short unsigned int}' to 'uint16_t* {aka short unsigned int*}' [-fpermissive]
PaulS:
Any example which can help me to get the idea :slight_smile:
Study arrays :wink: And forget about names. You can’t build a name and pretend it’s the name of a variable.
uint16_t onn [][227] =
{2980, 1802,  448, 1102,  394, 1134,  418, 408,  418, 410,  418, 434,  392, 1156,  448, 380,  392, 448,  394, 1156,  420, 1130,  394, 410,  418, 1158,  392, 434,  420, 406,  394, 1156,  394, 1172,  448, 356,  416, 1156,  394, 1158,  394, 434,  392, 434,  394, 1158,  392, 434,  394, 450,  392, 1156,  394, 434,  394, 434,  392, 408,  418, 434,  392, 434,  394, 410,  418, 448,  394, 434,  394, 410,  416, 410,  418, 434,  392, 434,  394, 434,  394, 434,  392, 448,  392, 434,  392, 434,  394, 1156,  392, 434,  392, 434,  394, 1158,  392, 434,  394, 448,  394, 1158,  392, 1158,  394, 434,  392, 434,  392, 436,  418, 408,  392, 434,  392, 450,  392, 410,  418, 434,  394, 410,  416, 436,  392, 408,  442, 410,  392, 434,  392, 448,  394, 434,  394, 434,  392, 434,  394, 434,  392, 434,  394, 410,  416, 1134,  416, 448,  394, 434,  392, 436,  392, 434,  392, 434,  394, 410,  416, 434,  392, 434,  420, 422,  392, 434,  392, 434,  394, 434,  394, 434,  394, 432,  418, 408,  394, 434,  394, 426,  416, 434,  418, 384,  418, 434,  394, 434,  392, 434,  418, 384,  416, 434,  394, 448,  394, 434,  394, 432,  394, 434,  394, 434,  392, 434,  394, 410,  444, 408,  394, 448,  394, 434,  418, 410,  392, 1158,  418, 1130,  394, 1158,  394, 1156,  448, 1104,  392, 428,  416},  // UNKNOWN F0A17D53
Now you can basically use onn[0] and onn[1]. If you want to use 27 and 30, you need some intelligence to convert 30 to 0 and 27 to 1.
onn.c_str()[3]
The length of the array that c_str() returns is 4. The element at position 3 is a NULL. Converting a NULL string to a number is not meaningful.
Even if the first argument WAS a string representing a numeric value, converting the string to an unsigned int in base 0 makes no sense.
sterretje:
yes this is a good way but in this way I want a way to convert 30 to 0 and 27 to 1!
PaulS:
The conversion is to an unsigned long mismatching the target int in probably two aspects.
Zero for the base in strtoul means unspecified, allowing 0x 0b 07 defaulting to decimal.
