I want to find the surname as a variable but idk where it is?
I am following an example and want to know what I can run in order to assign the last name read off a swipecard as string into a variable so I can then use that to only allow cards with a certain surname or identifier, etc. I am not really into programming and am not sure how to do this as I just wanna make something for fun for my house and idk what to do. Help is appreciated <3
#include <SPI.h>
#include <MFRC522.h>
// Include the Servo library
#include <Servo.h>
// Declare the Servo pin
int servoPin = 3;
// Create a servo object
Servo Servo1;
#define RST_PIN         9           // Configurable, see typical pin layout above
#define SS_PIN          10          // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance
  Serial.begin(9600);                                           // Initialize serial communications with the PC
  SPI.begin();                                                  // Init SPI bus
  mfrc522.PCD_Init();                                              // Init MFRC522 card
  Serial.println(F("Read personal data on a MIFARE PICC:"));    //shows in serial that it is ready to read
  // We need to attach the servo to the used pin number
   Servo1.attach(servoPin);
  // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
  MFRC522::MIFARE_Key key;
  for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
  //some variables we need
  byte block;
  byte len;
  MFRC522::StatusCode status;
  // Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    return;
  Serial.println(F("**Card Detected:**"));
  mfrc522.PICC_DumpDetailsToSerial(&(mfrc522.uid)); //dump some details about the card
  //mfrc522.PICC_DumpToSerial(&(mfrc522.uid));      //uncomment this to see all blocks in hex
  Serial.print(F("Name: "));
  byte buffer1[18];
  block = 4;
  len = 18;
  //------------------------------------------- GET FIRST NAME
  status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid)); //line 834 of MFRC522.cpp file
  if (status != MFRC522::STATUS_OK) {
    Serial.print(F("Authentication failed: "));
    Serial.println(mfrc522.GetStatusCodeName(status));
    return;
  status = mfrc522.MIFARE_Read(block, buffer1, &len);
    Serial.print(F("Reading failed: "));
    return;
  //PRINT FIRST NAME
  for (uint8_t i = 0; i < 16; i++)
    if (buffer1[i] != 32)
      Serial.write(buffer1[i]);
  Serial.print(" ");
  //---------------------------------------- GET LAST NAME
  byte buffer2[18];
  block = 1;
  status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 1, &key, &(mfrc522.uid)); //line 834
    return;
  status = mfrc522.MIFARE_Read(block, buffer2, &len);
    return;
  //PRINT LAST NAME
  for (uint8_t i = 0; i < 16; i++) {
   Serial.write(buffer2[i]);
  Serial.println(F("\n**End Reading**\n"));
  delay(1000); //change value if you want to read cards faster
  mfrc522.PICC_HaltA();
  mfrc522.PCD_StopCrypto1();
after 1 hour 14 views and zero answers.
What do you think is the reason that you don't get answers?
https://www.google.de/search?q=arduino+RFID+accesscontrol
If you uncomment that line that says "uncomment this to see all blocks in hex" where does the surname show up in the data?
