I am trying to upload from Arduino to Firestore and receive the uploaded data to Android Studio.
What do I need to modify in the following code to receive it in the tournament method (Quarterfinals, Semifinals)?
#include <SoftwareSerial.h>
const byte rxPin = 4;
const byte txPin = 5;
// Set up a new SoftwareSerial object
SoftwareSerial mySerial (rxPin, txPin);
const int buttonPin = 8; // Integer to indicated which pin the button is connected to.
int buttonState = 0; // Integer to store data from the button.
int scoreBlue = 0; // Variable to count the score for the blue team.
int scoreRed = 0; // Variable to count the score for the red team.
boolean addScoreBlue = false; // Boolean to trigger animation, blue lights and increase in score for the blue team.
boolean addScoreRed = false; // Boolean to trigger animation, red lights and increase in score for the red team.
int lineTrackerTriggeredBlue = 0; // Variable to display animation and blue light show first and then add the score afterwards.
int lineTrackerTriggeredRed = 0; // Variable to display animation and red light show first and then add the score afterwards.
#include <Adafruit_NeoPixel.h> // Including Adafruit library to control the NeoPixel.
int lightDelay = 10; // Integer for length of delay in light shows.
const int Pin = 7; // Varible for the pin where the NeoPixel strip is connected to
const int NumberOfPixels = 112; // Variable for the number of pixels in the NeoPixel strip
Adafruit_NeoPixel pixels(NumberOfPixels, Pin, NEO_GRB + NEO_KHZ800); //The type of NeoPixel is defined.
mySerial.begin(9600); // Initializes the serial monitor and Nextion display.
attachInterrupt(0, addscoreblue, FALLING); // Calls the function "addscoreblue" when signal from blue's line tracker is triggered.
attachInterrupt(1, addscorered, FALLING); // Calls the function "addscorered" when signal from red's line tracker is triggered.
pinMode(buttonPin, INPUT_PULLUP); // Defining the button as an input.
pixels.begin(); // Initialises the NeoPixel strip.
for (int i = 0; i < 28; i++) { // For loop to manage one half of the LED strip.
pixels.setPixelColor(i, pixels.Color(0, 0, 255)); // Half of the LED's is set to blue.
pixels.show();
} // Send the updated pixel colors to the hardware.
for (int i = 28; i < 84; i++) { // For loop to manage the other half of the LED strip.
pixels.setPixelColor(i, pixels.Color(255, 0, 0)); // Sets the other half of LED's to red.
pixels.show();
for (int i = 84; i < NumberOfPixels; i++) { // For loop to manage one half of the LED strip.
pixels.show();
if (addScoreBlue == true) { // If the blue team scores, the following code is executed.
lineTrackerTriggeredBlue++;
if (lineTrackerTriggeredBlue == 1) { // When the puck covers the line tracker, the animation and blue light show are displayed.
dynamicPixelsBlue(); // Function to display the blue light show is called.
mySerial.print("page 1"); // The page number is send to the Nextion display.
mySerial.write(0xff); // When something is send to a Nextion display, these three lines need to be called.
delay(3000); // Delay to let the animation play for 3 secs.
scoreBlue = scoreBlue + 1;
mySerial.print("page 0"); // The page number is send to the Nextion display to display the scoreboard again.
if (lineTrackerTriggeredBlue == 2) { // When is removed from the goal, the score is added in the Nextion display.
} // Resets the value, so code above can be repeated if blue team scores again.
if (lineTrackerTriggeredBlue == 3) {
if (lineTrackerTriggeredBlue == 4) {
addScoreBlue = false; // Sets the boolean to false again, so code above can be repeated if blue team scores again.
mySerial.print("n0.val="); // Defines that the following variable is a number.
mySerial.print(scoreBlue); // The variable of the blue team's score is send to the display.
if (addScoreRed == true) { // If the red team scores, the following code is executed.
lineTrackerTriggeredRed++;
if (lineTrackerTriggeredRed == 1) { // When the puck covers the line tracker, the animation and red light show are displayed.
dynamicPixelsRed(); // Function to display the red light show is called.
scoreRed = scoreRed + 1;
if (lineTrackerTriggeredRed == 2) { // When is removed from the goal, the score is added in the Nextion display.
} // Resets the value, so code above can be repeated if red team scores again.
if (lineTrackerTriggeredRed == 3) {
if (lineTrackerTriggeredRed == 4) {
addScoreRed = false; // Sets the boolean to false again, so code above can be repeated if red team scores again.
mySerial.print("n1.val="); // Defines that the following variable is a number.
mySerial.print(scoreRed); // The variable of the red team's score is send to the display.
buttonState = digitalRead(buttonPin); // The Arduino recieves data from the button and sets it as buttonState.
resetScore(); // Calls a function that detect if score needs to be resetted.
WhoWins(); // Calls a function to detect if one of the players won the game.
void addscoreblue() { // Function that is called when blue team scores.
addScoreBlue = true;
} // Sets boolean to true, so statement in loop is triggered.
void addscorered() { // Function that is called when red team scores.
addScoreRed = true;
void resetScore() { // Function to reset the score if the button is pressed.
if (buttonState == LOW) {
scoreRed = 0;
scoreBlue = 0;
void dynamicPixelsBlue() { // Function to make a light show when blue team scores.
pixels.clear(); // Turns off all LED's, so it's ready for the following light pattern.
for (int i = 0; i < NumberOfPixels; i++) { // For loop to make wave effect with 10 pixels.
pixels.setPixelColor(i, pixels.Color(0, 0, 255)); // Pixel i is set to blue.
pixels.setPixelColor(i - 10, pixels.Color(0, 0, 0)); // The pixel that is 10 behind of pixel i is turned off.
pixels.show(); // Send the updated pixel colors to the hardware.
delay(lightDelay);
} // Pause before next pass through loop
for (int i = 56; i > 0; i--) { // For loop to make wave effect with 10 pixels but in the other direction than above.
pixels.setPixelColor(i + 10, pixels.Color(0, 0, 0)); // The pixel that is 10 infront of pixel i is turned off.
delay(lightDelay);
for (int i = 0; i < NumberOfPixels; i++) { // For loop to turn on all pixels.
} // Sets all pixels to blue.
delay(lightDelay + 200); // Keeps all LED's on for 210 millisecs.
for (int i = 0; i < NumberOfPixels; i++) { // For loop to turn off all pixels.
pixels.setPixelColor(i, pixels.Color(0, 0, 0));
} // Sets all pixels to no color (off).
delay(lightDelay + 200); // Keeps all LED's off for 210 millisecs.
void dynamicPixelsRed() { // Exactly same function and structure as the blue light show, but the color is instead red.
pixels.clear();
pixels.show();
delay(lightDelay);
pixels.show();
delay(lightDelay);
pixels.show();
pixels.show();
pixels.show();
pixels.show();
void WhoWins() { // Function to display winner animation.
if (scoreBlue == 5) { // If blue team scores three goals, the blue winner animation is displayed.
mySerial.print("page 2"); // The page number is send to the Nextion display.
delay(5000); // Delay to let the animation play for 5 secs.
resetScoreAfterWin(); // Calls function to reset score.
if (scoreRed == 5) { // If red team scores three goals, the blue winner animation is displayed.
mySerial.print("page 3"); // The page number is send to the Nextion display.
void resetScoreAfterWin() { // Function to reset score when one of the players won the game.
scoreRed = 0;
scoreBlue = 0;
