the is peace of code i do not understand its meaning
if (this->_neutralVoltage == float() || isnan(this->_neutralVoltage))
here he is checking value to be equal to float() what is that means ? is that means if its float value this if condition will be true ?
See Value initialization - cppreference.com and https://en.cppreference.com/w/cpp/language/zero_initialization :
T ()
If T
is a scalar type, the object's initial value is the integral constant zero explicitly converted to T
So float()
is the same as float(0)
Not sure why the author didn't simply write 0
or 0.f
so that means if the value of float is zero this condition is true ?
Yes, if the value of the member variable this->_neutralVoltage
is zero (or NaN), the condition will be true
Koepel
5
That float()
is zero initialized is new for me as well. In my opinion, programming is also making clear what is going on.
I think I found the origin here: DFRobot_ESP_PH_BY_GREENPONIK/DFRobot_ESP_PH.cpp at master · GreenPonik/DFRobot_ESP_PH_BY_GREENPONIK · GitHub
Perhaps it is a mistake and it was a check if the number is a float ?
The goal is to check if a valid float number was read from EEPROM.
It does not make sense to me, to store a float number but it may not be 0.0
The original code is from DFRobot. They have:
if(EEPROM.read(PHVALUEADDR)==0xFF && EEPROM.read(PHVALUEADDR+1)==0xFF && EEPROM.read(PHVALUEADDR+2)==0xFF && EEPROM.read(PHVALUEADDR+3)==0xFF){
That I understand
system
Closed
6
