I want to learn about arduino
hi...
I'm very interested in your code, but here I also have a code for a keyboard or piano, with a standard number of 61 keys, and I also have a separate code specifically for pitch bend, which I want to ask, how do I combine it into These 2 codes, I really hope for all of my friends' help
and this is my code...
#include <MIDI.h>
#include <Keypad.h>
const byte ROWS = 8; //turun
const byte COLS = 8; //samping
char keys[COLS][ROWS] = {
{36, 37, 38, 39, 40, 41, 42, 43},
{44, 45, 46, 47, 48, 49, 50, 51},
{52, 53, 54, 55, 56, 57, 58, 59},
{60, 61, 62, 63, 64, 65, 66, 67},
{68, 69, 70, 71, 72, 73, 74, 75},
{76, 77, 78, 79, 80, 81, 82, 83},
{84, 85, 86, 87, 88, 89, 90, 91},
{92, 93, 94, 95, 96, 97, 98, 99}
byte rowPins[ROWS] = {2, 3, 4, 5, 6, 7, 8, 9};
byte colPins[COLS] = {A0, A1, A2, A3, A4, A5, 10, A7};
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
byte pressed = 32;
byte chanel = 0;
Serial.begin(115200);}
if (kpd.getKeys()){
for (int i = 0; i < LIST_MAX; i++) {
if ( kpd.key[i].stateChanged )   {
pressed = kpd.key[i].kchar + 0; // 0 61key C // 12 49key F //
switch (kpd.key[i].kstate) {
case PRESSED:
sendMIDI(chanel | 0x90, pressed, 100);
case RELEASED:
sendMIDI(chanel | 0x80, pressed, 64);
} // End loop
void sendMIDI(byte type, byte note, byte velocity){
Serial.write(type);
Serial.write(note & 0x7F);
Serial.write(velocity);}
and this is the code for the pitch bend.....
#include <MIDIUSB.h> // include MIDIUSB library
#include <pitchToNote.h> //
int joyX = 0; //Pitch Bend
int joyY = 0; //CC1 und CC20
int pitchBend = 0;
int controllerWert = 0;
int button = LOW;
int buttonAlt = LOW;
int schalter = 0;
//Serial.begin(9600);} //hairless-midiserial
Serial.begin(31250);} //Midi arduino 16u2
joystickAbfragen();
buttonAbfragen();
void joystickAbfragen() {
joyX = analogRead(A0);
if (joyX > 536) {
pitchBend = map(joyX,530,1023,65,127);
sendeMIDI(224,0,pitchBend);
if (joyX < 400) {
pitchBend = map(joyX,0,520,0,63);
else if ((joyX > 520 && joyX < 530) && pitchBend != 64) {
pitchBend = 64;
joyY = analogRead(A1);
if (joyY > 528) {
controllerWert = map(joyY,530,1023,0,127);
sendeMIDI(176,1,controllerWert);
else if (joyY < 520) {
controllerWert = map(joyY,520,0,0,127);
void buttonAbfragen() {
if (button == LOW && buttonAlt == HIGH) {
if(schalter == 0){
sendeMIDI(176, 64, 127);
schalter = 1;
else {
sendeMIDI(176, 64, 0);
schalter = 0;
buttonAlt = button;
void sendeMIDI(int statusByte, int dataByte1, int dataByte2) {
Serial.write(statusByte);
Serial.write(dataByte1);
Serial.write(dataByte2);
and please help me, because I'm having a lot of trouble, combining these 2 codes, I really hope, I can get the solution here
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
