Hello everyone.. I bought a 5-axis robot arm kit, made it all, and tried to operate it, but I want to do emergency braking by attaching an additional sensor. But I'm not very good at it, so I don't know what to do..
The robot arm uses an Arduino Uno-based board made at the place where it was purchased, and the sensor I want to use is a self-made sensor, which is an analog sensor that outputs a voltage when a human touches it. This analog signal was connected to the Arduino Uno board and converted into a digital signal, and then the signal was put on the robot arm driving board.
If the robot arm normally collides with another object, I want to make a code that stops and repeats the original motion at the stop again after a certain period of time!!
const int sensorPin = A1; // sensor analog input
const int ledPin = 12; // OUTPUT digital pin
int val = 0;
pinMode(ledPin,OUTPUT);
val = analogRead(sensorPin);
if (val>600) // If the analog signal is 600 or more, 1 output as a digital signal
digitalWrite(ledPin,1);
delay(50);
Serial.println(1);
digitalWrite(ledPin,0);
delay(50);
Serial.println(0);
#include <MsTimer2.h> // interrupt
#include <Servo.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
#include <Sleep_n0m1.h> // for emergency stop
Adafruit_SSD1306 display(128,64,&Wire,OLED_RESET);
const int ledPin = 8; // input digital signal
Sleep sleep;
unsigned long sleepTime; // for emergency stop time
Servo base,arm1, arm2, wrist, gripper;
Servo servo[5] = {base,wrist,arm2,arm1,gripper};
int angle = 0;
int i=0;
pinMode(ledPin,INPUT); // for OLED
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // for OLED
display.setTextColor(WHITE); // for OLED
display.clearDisplay(); // for OLED
base.attach(9);
base.write(0);
wrist.attach(6);
wrist.write(90);
arm2.attach(5);
arm2.write(50);
arm1.attach(3);
arm1.write(90);
gripper.attach(11);
gripper.write(90);
MsTimer2::set(100,interrupt_sensor); // interrupt
MsTimer2::start();
sleepTime = 5000; // stop time
display.setTextSize(2); // set the font size
display.setCursor(25,25); //set the display location
display.print("ASD Lab."); //string displayed
display.display();// began to show
for (i; i<40; i++)
arm1.write(120);
delay(50);
for(angle=0 ; angle < 140 ; angle++) // base drive control
base.write(angle);
delay(15);
for(angle = 50; angle>10;angle--) // arm2 drive control
arm2.write(angle);
delay(15);
for(angle=90; angle > 35 ; angle--)// gripper drive control
gripper.write(angle);
delay(15);
for (angle = 10; angle < 50; angle++) // arm2 drive control
arm2.write(angle);
delay(15);
for(angle = 140; angle > 0 ; angle--)//base drive control
base.write(angle);
delay(15);
for (angle=50 ; angle > 10; angle--) // arm2 drive control
arm2.write(angle);
delay(15);
for(angle=35; angle < 90; angle++) // gripper drive control
delay(15);
for (angle=10 ; angle < 50 ; angle++) //arm2 drive control
arm2.write(angle);
delay(15);
void interrupt_sensor () {
int val = digitalRead(ledPin); //digital signal
Serial.println(val);
if (val == 1){ // If the digital input is detected as 1, the robot arm stops immediately.
Serial.println("Emergency STOP!");
arm1.write(120);
sleep.pwrDownMode();
sleep.sleepDelay(sleepTime);
How can I make sure it works and gives better results?
please help me....
