I want to map my robot so that it can follow that map and become autonomous
Can somone tell how to do room mapping with arduino
Welcome to the forum
Do you want the robot to map the room or are you going to supply the robot with a map ?
How does your robot know, with sufficient accuracy, where it is in the room and maybe in which direction it is pointing ?
With a Hexapod I built I used LIDAR to scan and map a room. The hexapod was able to walk around and avoid objects with the LIDAR and some code.
Map the room
Any website link which can help me??
I guess thats a obstacle avoiding bot, but i want to map a room or a house so i can tell my robot to go from one room to another autonomously
RSSI.
Rooms in the house could be described using RSSI. Let's say you are able to receive 4 RSSI signals. In each room the 4 RSSI signals would be unique to the room. Once the rooms RSSI signals are known, now the robot know where to go and can avoid thingies in the way.
Don't you think you should have disclosed that in post#1?
Shifting Goal Posts.
Ok thank you for the reply
Some other way in which i can get a vissual map and navigate my robot accordingly
Use a FPV drone cam mounted to the robot.
You could put up transmission beacons.
You could use gps.
Thank you for helping
Any video or documentation on it??
