i want to on and off the pin using sensor value.if sensor value high relay pin/valve should on. but if we send on command from wifi it should on the relay even though the sensor value is low.
i have written code but when im making on from wifi module while sensor is high . after few seconds it goes off
code/sketch
#include "SoftwareSerial.h"
#include <SPI.h>
//#define digmoisturePin 52
#define digmoisturePin 11
SoftwareSerial esp(8,9);
int relay = 6;
int number = 1 ;
esp.begin(9600);
esp.println("AT+CWMODE=3");
delay(50);
if (esp.find("OK"))
Serial.println("MODE 3 ACTIVATED");
else{
Serial.println("NOT ACTIVATED");
//MULTIPLE CONNECTIONS//
esp.println("AT+CIPMUX=1");
if (esp.find("OK"))
Serial.println("tcp initiated");
//HTTP PORT //
esp.println("AT+CIPSERVER=1,80");
if (esp.find("OK"))
Serial.println("ok");
else {
Serial.println("denied");
pinMode(relay, LOW);
esp.begin(9600);
// setting the led pins to outputs
pinMode(digmoisturePin, INPUT);
// setting the relay pin to outputs
pinMode(relay, OUTPUT);
// the loop routine runs over and over again forever:
Serial.println(esp.read());
if(esp.available() > 0)
delay(2000);
wifiControl();
//Serial.println(esp.read());//-1
Serial.println("Read");
if(digitalRead(digmoisturePin) == HIGH){
Serial.println("1");
digitalWrite(relay, HIGH);
else {
Serial.println("0");
String incomingByte1=esp.readString();
int SemicolonPosition1 = incomingByte1.indexOf(':');
if(incomingByte1.charAt(SemicolonPosition1 + 2) == 'N' ||incomingByte1.charAt(SemicolonPosition1 + 2) == 'n')
//number=2 ;
Serial.println("inner loop ON");
digitalWrite(relay, LOW);
void wifiControl()
if (esp.available() > 0) {
// String incomingByte = esp.readString();
String incomingByte=esp.readString();
int SemicolonPosition = incomingByte.indexOf(':');
//Serial.println(spacePosition);
if (incomingByte.charAt(SemicolonPosition + 2) == 'N') {
enter code here Serial.println("Valve switched ON");
digitalWrite(11,LOW);
digitalWrite(relay,HIGH);
esp.println("AT+CIPSEND=0,8");
esp.println("WATER ON");
Serial.println("ten sec delay");
delay(10000);
if (incomingByte.charAt(SemicolonPosition + 2) == 'F') {
Serial.println("Valve Switched OFF");
digitalWrite(relay,LOW);
digitalWrite(11,HIGH);
esp.println("AT+CIPSEND=0,9");
delay(1000); // delay 1 second between reads
attached code
post_sample_wifi_smart_garden.ino (2.76 KB)
