I want to ON one by one 16 led using two shift register
I want to on 16 leds one after one using two 74HC595 shift register. I have write this code but not working. anybody can help me ?
const int latchPin = 3;
const int clockPin = 2;
const int dataPin = 4;
byte led[16] = {0b1000000000000000,
                0b0100000000000000,
                0b0010000000000000,
                0b0001000000000000,
                0b0000100000000000,
                0b0000010000000000,
                0b0000001000000000,
                0b0000000100000000,
                0b0000000010000000,
                0b0000000001000000,
                0b0000000000100000,
                0b0000000000010000,
                0b0000000000001000,
                0b0000000000000100,
                0b0000000000000010,
                0b0000000000000001};
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  for (int i = 0; i < 16; i++)
    byte lowLED = lowByte(led[i]);
    byte highLED = highByte(led[i]);
    digitalWrite(latchPin, LOW);
    shiftOut(dataPin, clockPin, LSBFIRST, lowLED);
    shiftOut(dataPin, clockPin, LSBFIRST, highLED);
    digitalWrite(latchPin, HIGH);
Please help.
0b00001111 syntax can be applied only to byte values - so no more than 8 bits long
You should store your high and lowbyte in two separate uint8_t variables if you want to use "0b" notation.
But the best is calculate it in place before shifting out with shifting bits operations
@b707
then how can i fix it ?
you do not need the led[] array at all
    byte lowLED = lowByte(1 << i );
    byte highLED = highByte(1 << i );
@b707
Thanks for your help it's working. but it is starting from 16th led how can i starting from 1st led ?
and one more question is if i want to on only 12 number of led then how can i ON ?
and can you help me to understand you code ? i am new to arduino so please
for example
byte lowLED = lowByte(1 << (15 -i) );
byte highLED = highByte(1 <<(15 - i) );
I changed only one operator in your code. All you need to understand is to read something about the bit shift operator x << y
Sorry, but it's hard for me to explain this in more detail because I don't know English well
@b707
can you please help me for this ?
Thank you!
just replace 16 to 12 in for loop condition
@b707
Not in loop i want say just only 12th LED. not other
you could guess yourself, no?
byte lowLED = lowByte(1 << 12);
byte highLED = highByte(1 <<12 );
Please mark the problem solved if you have received answers to questions :slight_smile:
