I want to output only when the accel value stays within a certain range for more
Hello :slight_smile:
I'm going to use the acceleration sensor and RGB LED to output different colors depending on the range of values of the sensor.
However, there is a problem where the led changes too quickly as the sensor values change rapidly.
So I'd like to print out the LED only when the sensor's value stays in a certain range for more than a second, but I don't know how to do it.
Can I find a similar example or something to refer to?
Thank you!
Got any code yet?
Do you understand how comparison expressions work?
Do you understand how the logical operators && and || work?
yscheol:
I'm not sure that this is the answer to your problem, if not it may help you to clarify what you want.
To do something only when a value has been exceeded for a period of time you need to think "upside down" and reset the clock every time the value is below the threshold. Like this
if (value < threshold) {
   lastTimeValueWasLow = millis();
if (millis() - lastTimeValueWasLow >= 1000) {
    // value was above the threshold for 1 second
...R
How many ranges? What are the limits of each range? What does the RGB do if the acceleration has not been in the current range for over a second?
If it were me, I would be more interested in the maximum acceleration over the last second. To do that I would keep a circular buffer of the last ten tenths of a second. When each new reading comes in, add it to the buffer and display based on the highest value in the buffer.
