I want to play mp3 when PIR is activated
I am using the following code. But mp3 doesn’t play
Who can help me?
#include "Arduino.h"
#include "Audio.h"
#include "SD.h"
#include "FS.h"
// Digital I/O used
#define SD_CS          5
#define SPI_MOSI      23    // SD Card
#define SPI_MISO      18
#define SPI_SCK       19
#define I2S_DOUT      25
#define I2S_BCLK      27    // I2S
#define I2S_LRC       26
const int PIN_TO_SENSOR = 2; //  pin connected to OUTPUT pin of sensor
int pinStateCurrent   = LOW;  // current state of pin
int pinStatePrevious  = LOW;  // previous state of pin
Audio audio;
   pinMode(PIN_TO_SENSOR, INPUT); // set ESP32 pin to input mode to read value from OUTPUT pin of sensor
    pinMode(5, OUTPUT);
    digitalWrite(5, LOW);
     SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
    if(!SD.begin(SD_CS))
      Serial.println("Error talking to SD card!");
      while(true);  // end program
    audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
    audio.setVolume(15); // 0...21
    audio.connecttoFS(SD,"/mysilverl.mp3");
void loop(){
  pinStatePrevious = pinStateCurrent; // store old state
  pinStateCurrent = digitalRead(PIN_TO_SENSOR);   // read new state
  if (pinStatePrevious == LOW && pinStateCurrent == HIGH) {   // pin state change: LOW -> HIGH
    Serial.println("Motion detected!");
    audio.loop();
  if (pinStatePrevious == HIGH && pinStateCurrent == LOW) {   // pin state change: HIGH -> LOW
    Serial.println("Motion stopped!");
    // TODO: turn off alarm, light or deactivate a device ... here
Tell us more
as you experienced from the other answer
the short answer just arises new questions:
  • what shall I tell more?
It is the same situation for your potential helpers
Your potential helpers need more information:
Where did you donwload the libraries
Audio.h ?
sd.h?
fs.h?
What exact type of microcontroller-board are you using?
What I2S-device are you using? please post a link to the data-sheet of this I2S-device
post a hand-drawn schematic of how
  • you have wired the I2S-device to the microcontroller
  • you have wired the SD-card-socket to the microcontroller
post a link to the datasheet of your I2S-device
post a link to the datasheet of your SD-card-socket
What file-format does the audio-library expect to read?
The microcontroller-world is not super-standardised like USB-devices.
You have to take care about more than just "Does the plug fit into the socket?"
best regards Stefan
