i want to use both serial monitor and lcd
can i both use both use lcd and serial monitor? if yes, pls help me, i trying to use both serial monitor and lcd in my mega arduino, 4x4 keyad, servo motor,coin acceptor. In my lcd output, it display an words something i didn't know what it is. I also research about serial pins, but i don't quite understand it. :frowning:
here my code:
// Coin to Bill System
#include <Servo.h>
Servo myservo;
// constants
const int coinpin = 20,ledpin = 13,button1 = 24; //here's my pins
int servoPin = 22,buttonState =0;
// Variables
volatile int pulse = 0,a=0;
Servo Servo1;
boolean bInserted = false;
boolean  b=0,c=0;
// Inventory Systems
#include <LiquidCrystal.h> //include LCD library (standard library)
#include <Keypad.h> //include keypad library - first you must install library (library link in the video description)
#define redLED 10 //define the LED pins
#define greenLED 11
char* password ="1234"; //create a password
int pozisyon = 0; //keypad position
const byte rows = 4; //number of the keypad's rows and columns
const byte cols = 4;
char keyMap [rows] [cols] = { //define the cymbols on the buttons of the keypad
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins [rows] = {2, 3, 4, 5}; //pins of the keypad
byte colPins [cols] = {6, 7, 8, 9};
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, rows, cols);
LiquidCrystal lcd (A0, A1, A2, A3, A4, A5); // pins of the LCD. (RS, E, D4, D5, D6, D7)
void setup(){
//Coin to Bill System
  attachInterrupt(digitalPinToInterrupt(coinpin), coinInterrupt, RISING);
  pinMode(ledpin, OUTPUT);
  Servo1.attach(servoPin);
  pinMode(button1,INPUT);
  lcd.begin(16, 2);
  pinMode(redLED, OUTPUT);  //set the LED as an output
  pinMode(greenLED, OUTPUT);
  setLocked (true); //state of the password
void loop(){
 myservoloop();
 checkButton1();
 checkcoin();
  char whichKey = myKeypad.getKey(); //define which key is pressed with getKey
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("    Welcome");
  lcd.setCursor(0, 1);
  lcd.print(" Enter Password");
  if(whichKey == '*' || whichKey == 'A' ||       //define invalid keys
  whichKey == 'B' || whichKey == 'C' || whichKey == 'D'|| whichKey == '#'){
    pozisyon=0;
    setLocked (true);
    lcd.clear();
    lcd.print("TRY AGAIN!");
    lcd.clear();
  if(whichKey == password [pozisyon]){
    pozisyon ++;
  if(pozisyon == 4){
    setLocked (false);
    lcd.clear();
    lcd.print("*** Verified ***");
    delay(3000);
    lcd.clear();
systemfunction();
  delay(100);
void systemfunction(){
   lcd.setCursor(0,0);
 lcd.print("Pls Enter your");
  lcd.setCursor(0,1);
  lcd.print("options:");
  lcd.setCursor(0,0);
  lcd.print ("Bill to coins[1]");
  lcd.setCursor(0,1);
  lcd.print ("Coins to Bill[2]");
  lcd.clear();
char whichKey = myKeypad.waitForKey();
 if(whichKey == '1'){// coin to bill system
  lcd.setCursor(0,0);
  lcd.print("Pls Enter Number");
  lcd.setCursor(0,1);
  lcd.print("of Coins:");
char coins;
String convert1,convert_integer1;
while(coins !='#'){
coins = myKeypad.waitForKey();
if(coins =='#'){
   return systemfunction();//return to system function
if(coins =='*'){
  return 0;
lcd.print(coins);
if(coins =='1'||coins =='2'||coins =='3'||coins =='4'||coins =='5'||coins =='6'||
 coins =='7'||coins =='8'||coins =='9'){
  convert1=String(convert1 + coins);
convert_integer1 = convert1.toInt();
 else if(whichKey == '2'){ //bill to coins system
   char bills;
  String convert2,convert_integer2;
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("of Bills:");
   while(bills !='#'){
    bills = myKeypad.waitForKey();
if(bills =='#'){
    lcd.print(bills);
   if(bills =='1'||bills =='2'||bills =='3'||bills =='4'||bills =='5'||bills =='6'||
 bills =='7'||bills =='8'||bills=='9'){
  convert2=String(convert2 + bills);
convert_integer2 = convert2.toInt();
  else{
    lcd.clear();
    lcd.print("Invalid Key!");
    lcd.clear();
void setLocked(int locked){
  if(locked){
    digitalWrite(redLED, HIGH);
    digitalWrite(greenLED, LOW);
    else{
      digitalWrite(redLED, LOW);
      digitalWrite(greenLED, HIGH);
void checkcoin(){
   if( bInserted  ){ // for show LED ON when Inserted
     bInserted = false;
     digitalWrite(ledpin, HIGH);
  }else{
  // Turn off LED
  digitalWrite(ledpin, LOW);
void checkButton1() {
  buttonState = digitalRead(button1);
// Interrupt
void coinInterrupt(){
  // Each time a pulse is sent from the coin acceptor,
  // interrupt main loop to add 1  and flip on the LED
  pulse++ ;
  a++;
  bInserted = true;
 // digitalWrite(ledpin, HIGH);
 // Serial.println( pulse );
void myservoloop(){
if(a==4 && buttonState == HIGH ){
  Servo1.write(0);
 Servo1.write(90);
  a=(a-4);
     bInserted = false;
  }else{
  // Turn off LED
// merging system codes
Yes
Does the LCD example "HelloWorld" program work OK ?
Have you developed your code in stages?
If so, then you must have written some code JUST to write to the LCD, to make sure your coding and connections are correct.
As @UKHeliBob has suggested, try one of the LCD library examples.
Tom.. :slight_smile:
