I want to use 'MAX31865' through 'STMDuino'
I want to use 'MAX31865' through 'STMDuino'.
  1. Adafruit_MAX31865 library : Adafruit PT100 RTD Temperature Sensor Amplifier - MAX31865 : ID 3328 : Adafruit Industries, Unique & fun DIY electronics and kits
  2. STM Core : MAPLE GitHub - rogerclarkmelbourne/Arduino_STM32: Arduino STM32. Hardware files to support STM32 boards, on Arduino IDE 1.8.x including LeafLabs Maple and other generic STM32F103 boards
    (board : STM32F103C8 / maple mini)
  3. Discussion on other sites: [maple mini] Adafruit_MAX31865 library : The correct value is not displayed. - Arduino for STM32
  4. source
#include <Wire.h>
#include "Adafruit_MAX31865.h"
// Use software SPI: CS, DI, DO, CLK
Adafruit_MAX31865 thermo = Adafruit_MAX31865(PA4, PA7, PA6, PA5);
#define RREF 430.0
#define RNOMINAL 100.0
void setup(){
  Serial.begin(115200); pinMode(PA4,OUTPUT);
  Serial.println("Adafruit MAX31865 PT100 Sensor Test!");
  thermo.begin(MAX31865_2WIRE); // set to 2WIRE or 4WIRE as necessary
  uint16_t rtd = thermo.readRTD();
  Serial.print("RTD value: ");
  Serial.println(rtd);
  float ratio = rtd;
  ratio /= 32768;
  Serial.print("Ratio = ");
  Serial.println(ratio, 8);
  Serial.print("Resistance = ");
  Serial.println(RREF * ratio, 8);
  Serial.print("Temperature = ");
  Serial.println(thermo.temperature(RNOMINAL, RREF));
  // Check and print any faults
  uint8_t fault = thermo.readFault();
  if (fault)
    Serial.print("Fault 0x");
    Serial.println(fault, HEX);
    if (fault & MAX31865_FAULT_HIGHTHRESH)
      Serial.println("RTD High Threshold");
    if (fault & MAX31865_FAULT_LOWTHRESH)
      Serial.println("RTD Low Threshold");
    if (fault & MAX31865_FAULT_REFINLOW)
      Serial.println("REFIN- > 0.85 x Bias");
    if (fault & MAX31865_FAULT_REFINHIGH)
      Serial.println("REFIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_RTDINLOW)
      Serial.println("RTDIN- < 0.85 x Bias - FORCE- open");
    if (fault & MAX31865_FAULT_OVUV)
      Serial.println("Under/Over voltage");
    thermo.clearFault();
I looked it up on the internet and it seems like the library is not compatible with 'STMDuino'.
Is there a solution?
When I want to use a library on an unsupported core badly enough, I generally try and figure out what the problem is, whether or not it can be fixed, and if it can fixed, then fixing it. After all, I was the one that wanted to use the library in the first place, so I'm the one with the motivation.
Do you "need" that particular core? ST has taken over publishing Arduino cores for their chips, and a much more recent core can be found at GitHub - stm32duino/Arduino_Core_STM32: STM32 core support for Arduino
(I don't know if that will fix your problems, but it moves you forward in history.)
