I want two for-loops to run at the same time
I want two for-loops to run at the same time, but it's not possible. Can anyone help me? this is my code
#include "HCPCA9685.h"
/* I2C slave address for the device/module. For the HCMODU0097 the default I2C address
is 0x40 */
#define  I2CAdd 0x40
int pos1=0;
int pos2=100;
int pos3=200;
int pos4=0;
int pos5=150;
/* Create an instance of the library */
HCPCA9685 HCPCA9685(I2CAdd);
  /* Initialise the library and set it to 'servo mode' */
HCPCA9685.Init(SERVO_MODE);
  /* Wake the device up */
HCPCA9685.Sleep(false);
  unsigned int Pos;
  HCPCA9685.Servo(2, 0);
  HCPCA9685.Servo(5, 0);
  HCPCA9685.Servo(8, 0);
  HCPCA9685.Servo(11, 0);
 HCPCA9685.Servo(1, 0);
 HCPCA9685.Servo(4, 0);
 HCPCA9685.Servo(7, 0);
 HCPCA9685.Servo(10, 0);
  HCPCA9685.Servo(0, 100);
  HCPCA9685.Servo(3, 100);
  HCPCA9685.Servo(6, 100);
  HCPCA9685.Servo(9, 100);
  for(Pos = 0; Pos< 150; Pos++)
 HCPCA9685.Servo(2, Pos);
 HCPCA9685.Servo(5, Pos);
 HCPCA9685.Servo(8, Pos);
 HCPCA9685.Servo(11, Pos);
 delay(10);
  for(Pos = 0; Pos< 80; Pos++)
 HCPCA9685.Servo(1, Pos);
 HCPCA9685.Servo(4, Pos);
 HCPCA9685.Servo(7, Pos);
 HCPCA9685.Servo(10, Pos);
 delay(10);
//    for(Pos = pos3; Pos>pos2; Pos-- && Pos = pos1; Pos<pos2; Pos++)
//  HCPCA9685.Servo(0, Pos);
//  HCPCA9685.Servo(3, Pos);
Your two loops has a different duration, so it can't be run at the exact same time. Be more specific in explanation of your needs.
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming Questions category of the forum
Are you trying to get two servos to run in opposite directions at the same time ?
for loop #1 takes roughly 150x10ms = 1.5s
for loop #2 takes roughly 80x10ms = 0.8s
do you want the servos to end up at their final position at the same time or it's OK for the second loop to end early ?
if the latter is OK, then you can just merge both loops and test if Pos has reached 80
for(Pos = 0; Pos< 150; Pos++)   {
  if (Pos < 80) {
 delay(10);
if you want both of them to arrive at the same time, you could use millis() and the map() function to calculate positions over time
here is an example on how to do this linear interpolation
struct Timing {
  const char * name;
  int startPos;
  int endPos;
  int currentPos;
Timing servoTimings[] = {
  {"servo1", 0, 149, 0},
  {"servo2", 0, 79, 0}
const byte count = sizeof servoTimings / sizeof * servoTimings;
const unsigned long duration = 1500;
unsigned long startTime;
  for (auto & st : servoTimings) st.currentPos = st.startPos;
  startTime = millis();
  if (millis() - startTime <= duration) {
    for (auto & st : servoTimings) {
      int newPos = map(millis() - startTime, 0, duration, st.startPos, st.endPos);
      if (st.currentPos != newPos) {
        st.currentPos = newPos;
        Serial.print(st.name); Serial.write('\t'); Serial.println(newPos);
    Serial.println("Done");
    while (true) yield(); // dies here
Work through these pages. The solution you're after is about the fifth page in, but it's really worth the time working through and understanding what's going on.
/* I2C slave address for the device/module. For the HCMODU0097 the default I2C address is 0x40 */
#define  I2CAdd 0x40
const int pos1 = 0;
const int pos2 = 100;
const int pos3 = 200;
const float pos4 = 80.0 / 150.0;
const int pos5 = 150;
  int Pos;
  HCPCA9685.Servo(2, pos1);
  HCPCA9685.Servo(5, pos1);
  HCPCA9685.Servo(8, pos1);
  HCPCA9685.Servo(11, pos1);
  HCPCA9685.Servo(1, pos1);
  HCPCA9685.Servo(4, pos1);
  HCPCA9685.Servo(7, pos1);
  HCPCA9685.Servo(10, pos1);
  HCPCA9685.Servo(0, pos2);
  HCPCA9685.Servo(3, pos2);
  HCPCA9685.Servo(6, pos2);
  HCPCA9685.Servo(9, pos2);
  for (Pos = pos1; Pos < pos5; Pos++)
    HCPCA9685.Servo(1, Pos * pos4);
    HCPCA9685.Servo(4, Pos * pos4);
    HCPCA9685.Servo(7, Pos * pos4);
    HCPCA9685.Servo(10, Pos * pos4);
    delay(10);
void loop() {}
can you post this lib? where you got it?
yes bro
thank you.its OK for the second loop to end early.
thanks
thank you kolaha. my problem was solved with your code.
To move two servos in opposite directions you only need a single for loop
For example, if the range of movement is 180 then the for loop would run from 0 to 180. You would write the for loop value to one servo and 180 minus the for loop value to the other
As you have changed the code in your original post I will leave it to you to work out the appropriate value for the for loop for the angles that you require
Are you understand the solution? If you will experience the similar problem in the future, would you able to adapt the code?
yes of course
thank you ukhelibob
Is there a solution for two For loops in opposite directions? I want both loops to work at the same time.
is 0x40 */
#define  I2CAdd 0x40
int pos1=0;
int pos2=100;
int pos3=200;
int pos5=150;
const float pos4=80.0/pos5;
  unsigned int Pos;
  for(Pos = pos1; Pos< pos5; Pos++)
 HCPCA9685.Servo(1, Pos*pos4);
 HCPCA9685.Servo(4, Pos*pos4);
 HCPCA9685.Servo(7, Pos*pos4);
 HCPCA9685.Servo(10, Pos*pos4);
 delay(10);
  for(Pos=pos2 ; Pos< pos3; Pos++)
 HCPCA9685.Servo(9, Pos);
 delay(10);
  for(Pos=pos2 ; Pos> pos1; Pos--)
 delay(10);
is the long term goal to move more than one sero to a various positons, either direction?
yes. i want to move to servos in to opposite directions at the same time
@alija22
You said that you understood @kolaha's solution? :slight_smile: Where does this question come from then?
In which direction to move the servos - same way or in opposite - does not matter if you understand the principle
Taking an interpolation approach with the map function would basically do the math for you
no the directions are important. kolaha's solution can't be used in opposite direction.
