I am doing a project that can give output from 2 ov7670 at the same time. I wanted to use Arduino Atmega2560 for that, as it has many digital and analog pins. Can anyone please help me regarding the code and connection, I have checked the form links
@system when I run your code, and set my serial monitor to the 1,000,000 baudrate, I see "*RDY*" followed by a lot of corrupted characters. Is there any reason I couldn't use:
Serial.print(byteToWrite);
instead of:
UDR0 = byteToWrite;
because when I use Serial.print() to print the data it shows up in the serial monitor as numbers instead of boxes, question marks, and the like.
Here is an example of what I am seeing when using your code as-is:
"⸮*RDY*SJ*b@⸮Άv⸮"... (except the garbage data con…
nonzung:
I forget that. I bought the camera ov7670 fifo.
Sorry and thank you so much.
Smart choice the one with the fifo is much better I wish I would have bought it but I bought the one without the fifo.
but the problem is I am not able to understand if my ov7670 has fifo or not. So I want a generalized code that can be used for both cameras. I am really confused at this point, plz help!
Thank you in advance
Assuming you bought it from a dealer what does the manual tell you?
it actually is just ov7670 i bought from normal shop,
This Module uses OV7670 image sensor, which is small in volume, works at low operating voltage, and provides all functions of a single chip VGA camera and image processor. Through SCCB bus control, the sensor can output the whole frame, sampling, and...
₹390.00
₹390.00
this is the similar one which i bought
system
Closed
November 21, 2023, 5:20pm
6
