i2c 24LC256 EEPROM Library - which one ?
Guys,
Trying to find the correct library to work in 1.04 with I2C EEPROM.
I have done a heap of searching but most of the libraries seem to be for the pre 1.0 environment and i am too much of a NOOB to know how to convert.
Does anyone have a known working Library for 1.04 that i can get pointed to please
(Any examples for a NOOb would also be much apppreciated)
Craig
Guys,
OK i found this code which does not need an external library (other than i2c) and seems to work well.
Note it only handles single byte reads and writes - and does not implement the page write feature
#include <Wire.h>
#define disk1 0x50    //Address of 24LC256 eeprom chip
void setup(void)
  Wire.begin();
  unsigned int address = 0;
  writeEEPROM(disk1, address, 123);
  Serial.print(readEEPROM(disk1, address), DEC);
void loop(){}
void writeEEPROM(int deviceaddress, unsigned int eeaddress, byte data )
  Wire.beginTransmission(deviceaddress);
  Wire.write((int)(eeaddress >> 8));   // MSB
  Wire.write((int)(eeaddress & 0xFF)); // LSB
  Wire.write(data);
  Wire.endTransmission();
  delay(5);
byte readEEPROM(int deviceaddress, unsigned int eeaddress )
  byte rdata = 0xFF;
  Wire.requestFrom(deviceaddress,1);
  if (Wire.available()) rdata = Wire.read();
  return rdata;
have a look at this - Arduino Playground - LibraryForI2CEEPROM -
Not tested with 1.0.4 so please do, if it not works let it know
robtillaart:
Thanks for the link - tried this one earlier and it does not work.
It uses the old send and receive methods rather than write and read.
I attempted to change those instances but then other errors were thrown up and it started getting too complex for me as a NOOB.
regards
Craig
craigcurtin:
robtillaart:
regards
Craig
Actually i have resolved this now - but do not feel qualified to upload the results
  1. the delay function was unknown - i remember reading about this somewhere so i did an include of the arduino.h in the header file - anyone know why this happens ?
  2. You were using the Wiring.h library - i changed this to Wire.h and everything seems to work.
I have not checked what the example is meant to do (line by line) - but i definitely get sensible looking results on my terminal.
I think these changes need to be made to the download code to bring it in line with 1.x environment - but being a NOOB do not want to fiddle with it
Craig
You can PM me the code in a zip if you want, then I will refactor it if needed and make an update on the playground.
Thanks Craigcurtin,
Merged your code with the latest existing and updated the playground article with latest version - Arduino Playground - HomePage -
