Hi guys,
I'm really new to use I2C to send data to a display. I have a sparkfun 7 segments display. I can run it perfect with the serial port. However, I need use serial port to send data through Bluetooth. Then, I found it can also run as a I2C device. It works ok until I found weird digit jumping.
The 0 should be shown on the right side instead of left.
Incorrect:
Correct:
This always happened when I plug in another arduino as I2C master board. When I do not plug the master board, It also happened twice. And, it will display normal when I unplug the power to reboot (tried reboot button, it will not change the digit location).
can someone help me on this problem? Thank you very much.
BBQube Slave 0.0.1
receive data from master unit
execute the code to control blower
05/04/2016
A5 to SCL
A4 to SDA
VIN to PWR
GND to GND
last version can not bootup reprogram from start..
//define LED Display
#include <Wire.h>
#define DISPLAY_ADDRESS1 0x71
//define arduino address
#define slave_address 8
//define Buttons
#include<Button.h>
#define PULLUP true
#define INVERT false
#define DEBOUNCE_MS 20
#define LONG_PRESS 1000
Button Button_play(4, PULLUP, true, DEBOUNCE_MS);
Button Button_set(7, PULLUP, INVERT, DEBOUNCE_MS);
#include<RotaryEncoder.h>
RotaryEncoder encoder(5, 6);
static int pos = 0;
#define Relay 8
#define FanPin 9
#define FanControl 10
#define led1 2
#define led2 3
int buttoncase, state, display_state;
int target_temp, target_input, target_temp_display;
int button_count, display_count;
int fan_power, temp_read, ES_upper, ES_lower;
int signal_slave, target_temp_hear, state_hear, P1_temp, signal_hear;
int Button_play_count;
int Inputread;
char tempString[10];
int Data_input [4] = {0, 0, 0, 0};
int Data_output [3] = {0, 0, 0};
unsigned long current_time, old_time, old_time_display;
uint8_t Buffer[3];
pinMode(FanPin, OUTPUT);
pinMode(FanControl, OUTPUT);
pinMode(Relay, OUTPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(Relay, HIGH);
signal_slave = 0;
target_temp_hear = 0;
state_hear = 0;
P1_temp = 0;
signal_hear = 0;
buttoncase = 0;
button_count = 0;
state = 0;
display_state = 0;
target_temp_display = 0;
target_temp = 0;
target_input = 200;
temp_read = 0;
fan_power = 0;
ES_upper = 0;
ES_lower = 0;
Button_play_count = 0;
Wire.begin(slave_address);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
Wire.endTransmission();
//Send the reset command to the display - this forces the cursor to return to the beginning of the display
Wire.beginTransmission(DISPLAY_ADDRESS1);
s7sSendStringI2C("----");
Wire.endTransmission(DISPLAY_ADDRESS1);
current_time = millis();//start count time as millisecond
case_select();
encoderread();
control();
led_control();
i2c_com();
LEDSendValue ();
void LEDSendValue () {
if (display_state == 0) {
target_temp_display = target_temp;
sprintf(tempString, "%4d", target_temp_display);
s7sSendStringI2C(tempString);
delay(50);
if (display_state == 1) {
target_temp_display = target_input;
if (current_time - old_time_display > 300) {
display_count = display_count + 1;
if ( (display_count % 2) == 0) {
delay(50);
else {
s7sSendStringI2C(" ");
old_time_display = current_time;
void clearDisplayI2C()
Wire.write(0x76); // Clear display command
void s7sSendStringI2C(String toSend)
for (int i = 0; i < 4; i++)
Wire.write(toSend[i]);
void encoderread() {
encoder.tick();
int newPos = encoder.getPosition();
if (pos != newPos) {
//Serial.println(newPos);
pos = newPos;
encoder.setPosition(0);
} // if
} // detect the encoder rotate
void case_select() {
Button_play.read();
Button_set.read();
encoderread();
switch (buttoncase) {
case 0:
if (Button_set.wasReleased()) {
buttoncase = 1;
button_count = 1;
Serial.println("triger");
else if (Button_set.pressedFor(LONG_PRESS)) {
if (state == 2) {
buttoncase = 2;
button_count = 3;
else {
buttoncase = 3;
button_count = 4;
else if (Button_play.pressedFor(LONG_PRESS)) {
state = 0;
target_temp = 0;
signal_slave = 1;
//Serial.println("triger");
else if (Button_play.wasReleased()) {
Button_play_count = Button_play_count + 1;
if (Button_play_count > 3) {
state = 1;
display_state = 0;
case 1:
if (pos == -1) {
target_input = target_input - 5;
button_count = 5;
else if (pos == 1) {
target_input = target_input + 5;
button_count = -5;
buttoncase = 0;
target_temp = target_input;
button_count = 0;
signal_slave = 1;
display_state = 1;
//check_connect = 1;
case 2:
state = 0;
buttoncase = 0;
case 3:
state = 2;
buttoncase = 0;
//Serial.print(buttoncase);
//Serial.print(":::");
//Serial.println(button_count);
void control() {
if (current_time - old_time > 2000) {
if (state == 0) {
fan_power = 0;
analogWrite(FanPin, fan_power);
else if (state = 1) {
fan_power = 255;
else if (state == 2) {
ES_upper = target_temp + 3;
ES_lower = target_temp - 3;
if (temp_read <= ES_lower) {
digitalWrite(Relay, LOW);
else if (temp_read >= ES_upper) {
else if (state == 3) {
Serial.print(Buffer[0]);
Serial.print(Buffer[1]);
Serial.println(Buffer[2]);
old_time=current_time;
void i2c_com() {
state_hear = Data_input[0];
target_temp_hear = Data_input[1];
P1_temp = Data_input[2];
signal_hear = Data_input[3];
if (signal_hear == 1) {
state = state_hear;
target_temp = target_temp_hear;
signal_slave = 2;
if (signal_hear == 2) {
signal_slave = 0;
void led_control () {
if (state == 0) {
digitalWrite(led1, HIGH);
digitalWrite(led2, HIGH);
void receiveEvent(int howMany) {
for (int i=0;i<4;i++) {
Data_input[i] = Wire.read();
Serial.print(Data_input[0]);
Serial.print(Data_input[1]);
Serial.print(Data_input[2]);
Serial.println(Data_input[3]);
void requestEvent() {
Data_output[0] = state;
Data_output[1] = target_temp;
Data_output[2] = signal_slave;
Buffer[0]=Data_output[0];
Buffer[1]=Data_output[1];
Buffer[2]=Data_output[2];
Wire.write(Buffer,6);
