I2C Address is Offset by 1 bit?
I am trying to use the wire library to communicate with a OV7670
If call
Wire.begin(0x42)
and sniff the I2C bus, what I actually see is communication to 0x84:
I note that this is offset by 1 bit - is this by design? How do I get the correct address placed on I2C bus?
Attempting to use 0x42 = 0b01000010
Actully placed on I2C bus 0x84 = 0b10000100
Yes this is perfectly normal.
The least significant bit you are seeing is the read / write bit, this may or may not be considered as part of the address. In the Arduino it is not.
Seven bit address plus R/W bit
