i2c addresses
All,
I'm trying to connect several temperature sensors to my arduino. These sensors will allow you to change their i2c address with some programming. I've figured out how to change the address, but I can't figure out what combination of letters or numbers I need to be using for the new address. The default for these sensors is 0x5A. I've had success changing one address to 0x55 (thanks to a sample code I found on this forum). So, I can connect 2 sensors. What addresses can I use to connect more?
As a shot in the dark, I tried changing to random addresses such as 0x57, 0x1D, 0x69... no luck. I have no idea what these numbers/letters mean, so I could be way off track.
Below is the code I'm using to change the address. This is the one I found online to change from 0x5A to 0x55:
#include <i2cmaster.h>
// Pins: Standard: SDA:A4  SCL:A5
//       Mega:     SDA:D20 SCL:D21
byte MLXAddr = 0x5A<<1;           // Default address
//byte MLXAddr = 0;               // Universal address
void setup(){
 Serial.println("Setup...");
 i2c_init();                              //Initialise the i2c bus
 PORTC = (1 << PORTC4) | (1 << PORTC5);   //enable pullups
 delay(5000);                    // Wait to allow serial connection
 ReadAddr(0);                    // Read current address bytes
 ChangeAddr(0x55, 0x00);         // Change address to new value
 //ChangeAddr(0x5A, 0xBE);       // Change address to default value
 ReadAddr(0);                    // Read address bytes
 delay(5000);                    // Cycle power to MLX during this pause
 ReadTemp(0);                    // Read temperature using default address
 ReadTemp(MLXAddr);              // Read temperature using new address
void loop(){
   delay(1000); // wait a second
word ChangeAddr(byte NewAddr1, byte NewAddr2) {
 Serial.println("> Change address");
 i2c_start_wait(0 + I2C_WRITE);    //send start condition and write bit
 i2c_write(0x2E);                  //send command for device to return address
 i2c_write(0x00);                  // send low byte zero to erase
 i2c_write(0x00);                  //send high byte zero to erase
 if (i2c_write(0x6F) == 0) {
   i2c_stop();                     //Release bus, end transaction
   Serial.println("  Data erased.");
 else {
   Serial.println("  Failed to erase data");
   return -1;
 Serial.print("  Writing data: ");
 Serial.print(NewAddr1, HEX);
 Serial.print(", ");
 Serial.println(NewAddr2, HEX);
 for (int a = 0; a != 256; a++) {
   i2c_write(NewAddr1);            // send low byte zero to erase
   i2c_write(NewAddr2);            //send high byte zero to erase
   if (i2c_write(a) == 0) {
     delay(100);                   // then wait 10ms
     Serial.print("Found correct CRC: 0x");
     Serial.println(a, HEX);
     return a;
 Serial.println("Correct CRC not found");
 return -1;
void ReadAddr(byte Address) {
 Serial.println("> Read address");
 Serial.print("  MLX address: ");
 Serial.print(Address, HEX);
 Serial.print(", Data: ");
 i2c_start_wait(Address + I2C_WRITE);  //send start condition and write bit
 i2c_rep_start(Address + I2C_READ);
 Serial.print(i2c_readAck(), HEX); //Read 1 byte and then send ack
 Serial.print(", ");
 Serial.print(", ");
 Serial.println(i2c_readNak(), HEX);
 i2c_stop();
float ReadTemp(byte Address) {
 int data_low = 0;
 int data_high = 0;
 int pec = 0;
 Serial.println("> Read temperature");
 Serial.print(", ");
 i2c_write(0x07);                  // Address of temp bytes
 // read
 data_low = i2c_readAck();         //Read 1 byte and then send ack
 data_high = i2c_readAck();        //Read 1 byte and then send ack
 pec = i2c_readNak();
 i2c_stop();
 //This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
 float Temperature = 0x0000;       // zero out the data
 // This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
 Temperature = (float)(((data_high & 0x007F) << 8) + data_low);
 Temperature = (Temperature * 0.02) - 273.16;
 Serial.print(Temperature);
 Serial.println(" C");
 return Temperature;
Do you really expect us to guess what sensors you are talking about?
Sorry, They are MLX90614 infrared temperature sensors.
"the SA (slave address) feature allows connecting up to 127 devices (SA=0x00...0x07F) with only 2 wires" From the Datasheet: https://www.sparkfun.com/datasheets/Sensors/Temperature/SEN-09570-datasheet-3901090614M005.pdf
that is a hexadecimal address, if you don't know what hex is Google it (or Hexadecimal - Wikipedia)
Little tip, always read the datasheet thoroughly. I promise you 90% of the questions you'll have that are hardware specific (like addresses) are in the datasheet.
Thanks. I had no idea what hex was so that's helpful. After a quick Google of hex, it looks like my efforts to change the address to 0x1D or 0x69 should have worked, but something isn't right, it's not working. All I did was change the 0x55 to 0x1D in the code above, what am I missing?
Look at this link, where somebody describes in detail how to change addresses on this device.
After having changed the addresses (one by one!) of your 2 sensors, hook them up to your Arduino on the I2C bus and run one of the I2C scanner sketches (link to the I2C scanner sketches - start with Nick Gammon's, which will do for most applications) to make sure that your sensors are found under the new addresses.
If you succeeded in confirming the new addresses you can go on with your sketch.
