I am creating a strain gauge Wheatstone Bridge circuit and needed to use a op amp in order to create a large enough of a signal for the Arduino. In looking for solutions I found the NAU7802 which contained a proper op amp and 24bit adc which would be helpful in my situation as I would prefer more accurate results.
The issue is that a) when i try and check that the ic is up an running with i2cdetect, nothing pops up, and b) my ldo/avdd is unresponsive as my wheatstone bridge stays at 0V. I think this is either my code or wiring. I know the wheatstone bridge works as i tested with a voltmeter. the rest of the wiring for the ic wasn't too difficult either so I think its a code issue. I think i followed all the steps to initialize the ic; its attached in the datasheet, the register numbers and functions are in the datasheet in section 11 and initializing set up is 9.1. Any help would be appreciated, this is my first time using the Wire library and i2c
Wire.begin();
Wire.beginTransmission(byte(0x2A));
Wire.write(byte(0x00)); //Write to PU Control
Wire.write(byte(0x21)); //Reset all register values
Wire.endTransmission();
Wire.write(byte(0x2E)); //Turn off Reset, Turn on PUDigital Circuit
delayMicroseconds(200); //Allow time for PWRUP Bit to = 1
Wire.write(byte(0xAE)); //Turn on LDO
Wire.write(byte(0xBE)); //Cyc Start
Wire.write(byte(0xB8)); //Power Down
Wire.write(byte(0xBE)); //Power Up
My experience with I2C is that if i2cdetect doesn't find your device then nothing else will work. I would check your wiring. Make sure you have the the pins correctly wired and some pullups on the 2 pins. When i2cdetect finds your device then try your code.
Beware the difference between Accuracy and Precision. Getting 24 bits of ADC accuracy would require monumentally good circuit design, layout, and shielding. You ain't gonna get that with a solderless breadboard with all those antennas.
im not the best at drawing these but i hope it helped. im not using the elegoo battery so i chose to exclude it from the schematic btw. swapped the capacitor on the VBG pin for a regular wire but that shouldnt change anything
VBG has to have a capacitor, it is part of the bypassing circuit to minimise noise, to keep the project stable and your reference voltage for the ADC. Not sure what SHORTING it to gnd will do.
The capacitors are also essential in the AVdd and Cfilter circuit for the same reason.
Especially when being built on protoboard.
is there a reason you are not using DRDY pin as in the application.
so i thought those were just for noise and as such i didnt think i needed them yet. I was looking to get the entire system set up then try and fix any noise in the circuit after.
for the drdy pin, i looked through google and couldnt find any way to interface it into the arduino so i left it thinking i only needed a data and clock wire for i2c
for the capacitors, do i need to follow the same capacitance values? i only have 10uF capacitors on hand right now
