i2C and IMU problem
Hi everybody,
I'm developing an arduino app to calibrate a gyro. I tried it on a arduino UNO and it works fine, and as same as in the DUE, but now I have a very strange trouble only with the DUE: The gyro (which employs i2C protocol) always reads +500 º/s, but only into X and Y axis!!!, that is crazy, and I have no idea about what can be happening. Please, Does anyone have the same problem?.
Sensor:
IMU -> MPU6050 based GY521 IMU.
Main code:
// Arduino IMU lector - Adaptado a necesidades
#include <Wire.h>
/* Constantes a leer */
int accX, accY, accZ;
int gyroX, gyroY, gyroZ;
int tempRaw;
double bgX, bgY, bgZ;
/* Variables para timer y buffer */
uint8_t i2cData[14]; // Buffer for I2C data
  // Inicializo IMU
  Wire.begin();
  Wire.flush();
  //TWBR = ((F_CPU / 400000L) - 16) / 2; // Set I2C frequency to 400kHz
  i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
  i2cData[1] = 0x06; // Disable FSYNC and set 5 Hz Acc filtering, 5 Hz Gyro filtering, 1 KHz sampling
  i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
  i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
  while (i2cWrite(0x19, i2cData, 4, false)); // Write to all four registers at once
  while (i2cWrite(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode
  while (i2cRead(0x75, i2cData, 1));
  if (i2cData[0] != 0x68) { // Read "WHO_AM_I" register
    Serial.print(F("Error reading sensor"));
    while (1);
  bgX = -2.075921122383778;
  bgY = -0.072308549354311;
  bgZ = 0.547682427661292;
  while (i2cRead(0x3B, i2cData, 14));
  accX = ((i2cData[0] << 8) | i2cData[1]); // Aceleración eje X (parte alta y parte baja)
  accY = ((i2cData[2] << 8) | i2cData[3]); // Aceleración eje Y (parte alta y parte baja)
  accZ = ((i2cData[4] << 8) | i2cData[5]); // Aceleración eje Z (parte alta y parte baja)
  tempRaw = (i2cData[6] << 8) | i2cData[7]; // Temperatura
  gyroX = (i2cData[8] << 8) | i2cData[9]; // Ratio de giro eje X
  gyroY = (i2cData[10] << 8) | i2cData[11]; // Ratio de giro eje Y
  gyroZ = (i2cData[12] << 8) | i2cData[13]; // Ratio de giro eje Z
  Serial.print((double) gyroX/131.0-bgX,10); Serial.print(","); Serial.print((double) gyroY/131.0-bgY,10);Serial.print(",");
  Serial.print((double) gyroZ/131.0-bgZ,10);
  Serial.print("\r\n");
  delay(10); // Espero 10 mili segundos (si pongo menos, matlab falla)
i2C library:
/* Copyright (C) 2012 Kristian Lauszus, TKJ Electronics. All rights reserved.
 This software may be distributed and modified under the terms of the GNU
 General Public License version 2 (GPL2) as published by the Free Software
 Foundation and appearing in the file GPL2.TXT included in the packaging of
 this file. Please note that GPL2 Section 2[b] requires that all works based
 on this software must also be made publicly available under the terms of
 the GPL2 ("Copyleft").
 Contact information
 Web      :  http://www.tkjelectronics.com
 e-mail   :  kristianl@tkjelectronics.com
const uint8_t IMUAddress = 0x68; // AD0 is logic low on the PCB
const uint16_t I2C_TIMEOUT = 1000; // Used to check for errors in I2C communication
uint8_t i2cWrite(uint8_t registerAddress, uint8_t data, bool sendStop) {
  return i2cWrite(registerAddress, &data, 1, sendStop); // Returns 0 on success
uint8_t i2cWrite(uint8_t registerAddress, uint8_t *data, uint8_t length, bool sendStop) {
  Wire.beginTransmission(IMUAddress);
  Wire.write(registerAddress);
  Wire.write(data, length);
  uint8_t rcode = Wire.endTransmission(sendStop); // Returns 0 on success
  if (rcode) {
    Serial.print(F("i2cWrite failed: "));
    Serial.println(rcode);
  return rcode; // See: http://arduino.cc/en/Reference/WireEndTransmission
uint8_t i2cRead(uint8_t registerAddress, uint8_t *data, uint8_t nbytes) {
  uint32_t timeOutTimer;
  uint8_t rcode = Wire.endTransmission(false); // Don't release the bus
  if (rcode) {
    Serial.print(F("i2cRead failed: "));
  Wire.requestFrom(IMUAddress, nbytes, (uint8_t)true); // Send a repeated start and then release the bus after reading
  for (uint8_t i = 0; i < nbytes; i++) {
    if (Wire.available())
      data[i] = Wire.read();
    else {
      timeOutTimer = micros();
      while (((micros() - timeOutTimer) < I2C_TIMEOUT) && !Wire.available());
      else {
        Serial.println(F("i2cRead timeout"));
        return 5; // This error value is not already taken by endTransmission
  return 0; // Success
Note: bias (bgX, bgY, bgZ) has been obtained previously using Matlab with the arduino UNO and the same code.
Thanks everyone.
Maybe it is the double data type? The Uno doesn't really use a double. It is the same as float. Both are 4 bytes. On the Due, float is 4 bytes and double is 8 bytes.
http://www.arduino.cc/en/Reference/Double
Just a thought...
Hi SurferTim,
It was the data type, for the DUE I have to use int16_t, and problem solved.
Thans!!!
