I2C and servo conflict?
I have a robot with four servos, one stepper, and six DC motors. Everything works great from a Mega board, until I try to add a secondary Nano board to run some lights and sound. It seems that when I add in the I2C function, the servos start picking up random noise or erroneous commands, as they start twitching erratically.
I've tried going through the libraries themselves to see if I2C is getting called at some point, hence creating a conflict, and can't find anything. But perhaps I'm missing something?
I'm using the following libraries:
Servo.h, ServoEasing.h, IBusBM.h, AccelStepper.h, Wire.h
Are you sure that the pins you are using for I2C are not already used for some other purpose in the sketch ?
Yes, I've checked. The SDA and SCL pins are free on both the boards.
We certainly are.
It would make things easier if you would post your code here. Read the forum guidelines to see how to properly post code and some hints on how to get the most from this forum.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Post a schematic showing how the project should be wired. Show the power supplies.
Well, that didn't last long.
#include <Servo.h>
#include <ServoEasing.h>
#include <IBusBM.h>
#include <AccelStepper.h>
#include <Wire.h>
// pins 2-13 control the DC motors
#define motorW1_IN1 6
#define motorW1_IN2 7
#define motorW2_IN1 4
#define motorW2_IN2 5
#define motorW3_IN1 2
#define motorW3_IN2 3
#define motorW4_IN1 13
#define motorW4_IN2 10
#define motorW5_IN1 8
#define motorW5_IN2 9
#define motorW6_IN1 11
#define motorW6_IN2 12
// Attach SDA and SCL to pins 20 and 21
ServoEasing servoW1;
ServoEasing servoW3;
ServoEasing servoW4;
ServoEasing servoW6;
ServoEasing servoCamTilt;
// pins 45-46 control the pan stepper
AccelStepper camPanStepper(1, 46, 45);  //(Type:driver, STEP, DIR) - Stepper1
IBusBM IBus;
IBusBM IBusSensor;
//int angle = 0;   // servo position in degrees
int ch0, ch1, ch2, ch3, ch4, ch5, ch6 = 0;
int servo1Angle = 90;
int servo3Angle = 90;
int servo4Angle = 90;
int servo6Angle = 90;
int s = 0; // rover speed
int r = 0; // turning radius
//int m1, m2, m3, m4, m5, m6;
int camTilt = 90;
int camPan = 0;
float speed1, speed2, speed3 = 0;
float speed1PWM, speed2PWM, speed3PWM = 0;
float thetaInnerFront, thetaInnerBack, thetaOuterFront, thetaOuterBack = 0;
float d1 = 271; // distance in mm
float d2 = 278;
float d3 = 301;
float d4 = 304;
byte x = 0;
int MODE = 3;
int OLDMODE = MODE;
  Wire.begin();
     Use this if you need to change the frequency of the PWM signals
    TCCR4B = TCCR4B & B11111000 | B00000101;     // D6,D7,D8 PWM frequency of 30.64 Hz
    TCCR2B = TCCR2B & B11111000 | B00000111;   // D9, D10 PWM frequency of 30.64 Hz
    TCCR1B = TCCR1B & B11111000 | B00000101;   // D11, D12  PWM frequency of 30.64 Hz
    TCCR5B = TCCR5B & B11111000 | B00000101; // D4, D13 PWM frequency of 30.64 Hz
    TCCR3B = TCCR3B & B11111000 | B00000101;    // D2, D3, D5 PWM frequency of 30.64 Hz
  IBus.begin(Serial1, IBUSBM_NOTIMER); // Servo iBUS
  IBusSensor.begin(Serial2, IBUSBM_NOTIMER); // Sensor iBUS
  IBusSensor.addSensor(IBUSS_INTV); // add voltage sensor
  // pins 22-26 control the servos
  servoW1.attach(22);
  servoW3.attach(23);
  servoW4.attach(24);
  servoW6.attach(25);
  servoCamTilt.attach(26);
  servoW1.write(90);
  servoW3.write(90);
  servoW4.write(90);
  servoW6.write(90);
  servoCamTilt.write(90);
  servoW1.setSpeed(550);
  servoW3.setSpeed(550);
  servoW4.setSpeed(550);
  servoW6.setSpeed(550);
  servoCamTilt.setSpeed(200);
  camPanStepper.setMaxSpeed(1000);
  camPan = 0;
  camTilt = 90;
  // DC Motors
  // Motor Wheel 1 - Left Front
  digitalWrite(motorW1_IN1, LOW);   // PWM value
  digitalWrite(motorW1_IN2, LOW); // Forward
  // Motor Wheel 2 - Left Middle
  digitalWrite(motorW2_IN1, LOW);
  digitalWrite(motorW2_IN2, LOW);
  // Motor Wheel 3 - Left Back
  digitalWrite(motorW3_IN1, LOW);
  digitalWrite(motorW3_IN2, LOW);
  // right side motors move in opposite direction
  // Motor Wheel 4 - Right Front
  digitalWrite(motorW4_IN1, LOW);
  digitalWrite(motorW4_IN2, LOW);
  // Motor Wheel 5 - Right Middle
  digitalWrite(motorW5_IN1, LOW);
  digitalWrite(motorW5_IN2, LOW);
  // Motor Wheel 6 - Right Back
  digitalWrite(motorW6_IN1, LOW);
  digitalWrite(motorW6_IN2, LOW);
  // Reading the data comming from the RC Transmitter
  // remember the IBus routine decrements the channel number by one, so sticks are channels 1-4
  IBus.loop();
  ch0 = IBus.readChannel(0);  // left-right steering
  ch1 = IBus.readChannel(1);  // camera tilt
  ch2 = IBus.readChannel(2);  // throttle
  ch3 = IBus.readChannel(3);  // camera pan
  ch4 = IBus.readChannel(4);  // fwd / rvs gear (SWA)
  ch5 = IBus.readChannel(9);  // lights on/off (SWD)
  ch6 = IBus.readChannel(8);  // light setting a/b/c (SWC)
  // at present, SWB, VRA, and VRB are unused
  // send color and light mode to AUX board; ch5 is power, ch6 selects the animation
  if (ch5 > 1500) {
    if (ch6 < 1300) {
      MODE = 0;
    else if (ch6 < 1700) {
      MODE = 1;
    else if (ch6 > 1700) {
      MODE = 2;
  else {
    MODE = 3;
  // As long as ch5 and ch6 are unchanged, do nothing. If they've changed, send the new mode.
  if (MODE != OLDMODE) {
    Wire.beginTransmission(0x14);
    Wire.write(MODE);
    Wire.endTransmission();
    OLDMODE = MODE;
  // Converting the incoming data
  // Steering right
  if (ch0 > 1515) {
    r = map(ch0, 1515, 2000, 1400, 600); // turning radius from 1400mm to 600mm
  // Steering left
  else if (ch0 < 1485) {
    r = map(ch0, 1485, 1000, 1400, 600); // turning radius from 600mm to 1400mm
  // Rover speed in % from 0 to 100
  s = map(ch2, 1000, 2000, 0, 100); // rover speed from 0% to 100%
  // Camera head steering
  if (ch1 < 1485 ) {
    if (camTilt >= 35) {
      camTilt--;
      delay(20);
  if (ch1 > 1515 ) {
    if (camTilt <= 165) {
      camTilt++;
      delay(20);
  servoCamTilt.startEaseTo(camTilt); // Camera tilt
  if (ch3 >= 1000 && ch3 < 1485) {
    camPan = map(ch3, 1000, 1485, 800, 0);
  else if (ch3 > 1515 && ch3 <= 2000) {
    camPan = map(ch3, 1515, 2000, 0, -800);
  else {
    camPan = 0;
  camPanStepper.setSpeed(camPan);    // Camera pan
  camPanStepper.run();
  calculateMotorsSpeed();
  calculateServoAngle();
  // Steer right
  if (ch0 > 1515) {
    // Servo motors
    // Outer wheels
    servoW1.startEaseTo(97 + thetaInnerFront); // front wheel steer right
    servoW3.startEaseTo(97 - thetaInnerBack); // back wheel steer left for overall steering to the right of the rover
    // Inner wheels
    servoW4.startEaseTo(94 + thetaOuterFront);
    servoW6.startEaseTo(96 - thetaOuterBack);
    // DC Motors
    if (ch4 < 1500) { // Move forward
      analogWrite(motorW1_IN1, speed1PWM);   // Outer wheels running at speed1 - max speed
      analogWrite(motorW2_IN1, speed1PWM);
      analogWrite(motorW3_IN1, speed1PWM);
      analogWrite(motorW4_IN2, speed2PWM); // Inner front wheel running at speed2 - lower speed
      analogWrite(motorW5_IN2, speed3PWM); // Inner middle wheel running at speed3 - lowest speed
      analogWrite(motorW6_IN2, speed2PWM); // Inner back wheel running at speed2 - lower speed
    else if (ch4 > 1500) {
      digitalWrite(motorW1_IN1, LOW);   // Outer wheels running at speed1 - max speed
      analogWrite(motorW1_IN2, speed1PWM);
      analogWrite(motorW2_IN2, speed1PWM);
      analogWrite(motorW3_IN2, speed1PWM);
      analogWrite(motorW4_IN1, speed2PWM);
      digitalWrite(motorW4_IN2, LOW); // Inner front wheel running at speed2 - lower speed
      analogWrite(motorW5_IN1, speed3PWM);
      digitalWrite(motorW5_IN2, LOW); // Inner middle wheel running at speed3 - lowest speed
      analogWrite(motorW6_IN1, speed2PWM);
      digitalWrite(motorW6_IN2, LOW); // Inner back wheel running at speed2 - lower speed
  // Steer left
    // Servo motors
    servoW1.startEaseTo(97 - thetaOuterFront);
    servoW3.startEaseTo(97 + thetaOuterBack);
    servoW4.startEaseTo(94 - thetaInnerFront);
    servoW6.startEaseTo(96 + thetaInnerBack);
    // DC Motors
      analogWrite(motorW1_IN1, speed2PWM);   // PWM value
      analogWrite(motorW2_IN1, speed3PWM);
      analogWrite(motorW3_IN1, speed2PWM);
      analogWrite(motorW4_IN2, speed1PWM);
      analogWrite(motorW5_IN2, speed1PWM);
      analogWrite(motorW6_IN2, speed1PWM);
    else if (ch4 > 1500) { // Move backward
      analogWrite(motorW1_IN2, speed2PWM); // Forward
      analogWrite(motorW2_IN2, speed3PWM);
      analogWrite(motorW3_IN2, speed2PWM);
      analogWrite(motorW4_IN1, speed1PWM);
      analogWrite(motorW5_IN1, speed1PWM);
      analogWrite(motorW6_IN1, speed1PWM);
  // Move straight
  else {
    servoW1.startEaseTo(97);
    servoW3.startEaseTo(97);
    servoW4.startEaseTo(94);
    servoW6.startEaseTo(96);
    // DC Motors
    if (ch4 < 1500) {
      analogWrite(motorW1_IN1, speed1PWM);  // all wheels move at the same speed
      digitalWrite(motorW1_IN1, LOW);  // all wheels move at the same speed
      analogWrite(motorW1_IN2, speed1PWM); // Forward
  // Monitor the battery voltage
  int sensorValue = analogRead(A0);
  float voltage = sensorValue * (5.00 / 1023.00) * 3.02; // Convert the reading values from 5v to suitable 12V
  // Send battery voltage value to transmitter
  IBusSensor.loop();
  IBusSensor.setSensorMeasurement(1, voltage * 100);
void calculateMotorsSpeed() {
  // if no steering, all wheels speed is the same - straight move
  if (ch0 > 1485 && ch0 < 1515) {
    speed1 = speed2 = speed3 = s;
  // when steering, wheels speed depend on the turning radius value
  else {
    // Outer wheels, furthest wheels from turning point, have max speed
    // Due to the rover geometry, all three outer wheels should rotate almost with the same speed. They differe only 1% so we asume they are the same.
    speed1 = s;
    // Inner front and back wheels are closer to the turing point and have lower speeds compared to the outer speeds
    speed2 = s * sqrt(pow(d3, 2) + pow((r - d1), 2)) / (r + d4);
    // Inner middle wheel is closest to the turning point, has the lowest speed
    speed3 = s * (r - d4) / (r + d4);
  // speed value from 0 to 100% to PWM value from 0 to 255
  speed1PWM = map(round(speed1), 0, 100, 0, 255);
  speed2PWM = map(round(speed2), 0, 100, 0, 255);
  speed3PWM = map(round(speed3), 0, 100, 0, 255);
void calculateServoAngle() {
  // Calculate the angle for each servo for the input turning radius "r"
  thetaInnerFront = round((atan((d3 / (r + d1)))) * 180 / PI);
  thetaInnerBack = round((atan((d2 / (r + d1)))) * 180 / PI);
  thetaOuterFront = round((atan((d3 / (r - d1)))) * 180 / PI);
  thetaOuterBack = round((atan((d2 / (r - d1)))) * 180 / PI);
Are you just here for the snark, or do you offer constructive advice?
I'd started to comment on the post you made earlier, and then you deleted it.
I was going to suggest meaningful names instead of "ch0", "ch1" etc.
Maybe some comments or named constants (instead of magic numbers) - don't make it difficult for people offering free help, particularly when it took three days to even see the code.
