I have a project where I want to control a motordriver with a potentiometer over i2C. I have my master sending the pot data correctly to the slave. I wish to use the data received in a switch/ case statement, and for some reason, I cant get it to work. The slave is receiving the data correctly but it is ignoring my attempt to turn the case into an array value (the speed of the motor).
the slave receives data (106, 107, 108, etc) and my switch statement should convert it into a number from the array (140, 130, 120) which is the speed of the motor, but for some reason doesnt. I feel like there is a basic error I’m making, but I cant see it. Any ideas?
#include <Wire.h>
// I/O PINS
//#define LED A2
#define SENSOR_A1 A1
// VARIABLES
byte dataFromI2C;
byte dataToI2C;
unsigned long millisJunction;
static unsigned long prevTime = 0;
bool SENSOR_A1_Trigger = false;
/////////////////////////////////////Speed array//////////////////////////////////////
////####################0,1,2,03,04,05,06,07,08,09,10,11,012,013,014,015,016,017,018,019,020,021,022,023//
byte speedArrayA [] = {0, 0, 0, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130, 140, 150, 160, 170, 180, 200, 220, 240};
//byte speedArrayB [] = {0, 0, 0, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130, 140, 150, 160, 170, 180, 200, 220, 240};
//byte speedArrayC [] = {0, 0, 0, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130, 140, 150, 160, 170, 180, 200, 220, 240};
byte speedTrainA = 0, speedTrainB = 0, speedTrainC = 0;
// Initializing I2C
Serial.begin(9600); // for debugging
Wire.begin(7); // set address #7
Wire.onReceive(receiveI2C);
Wire.onRequest(requestI2C);
Serial.println("Ready LOCAL 7: ");
Serial.print(SENSOR_A1_Trigger);
// pinMode(LED, OUTPUT);
pinMode(SENSOR_A1, INPUT);
// digitalWrite(LED, HIGH);
//sensor read
sensorRead();
// motorSpeed();
bool trainDir;
if (dataFromI2C != 0) Serial.println(dataFromI2C);
if (dataFromI2C != 0) {
Serial.println("go--");
switch (dataFromI2C) {
case 101: trainDir = 0 ; break; // fwd
case 102: trainDir = 1 ; break; //bwd
case 103: speedTrainA = speedArrayA[23]; break;
case 104: speedTrainA = speedArrayA[22]; break;
case 105: speedTrainA = speedArrayA[21]; break;
case 106: speedTrainA = speedArrayA[20]; break;
case 107: speedTrainA = speedArrayA[19]; break;
case 108: speedTrainA = speedArrayA[18]; break;
case 109: speedTrainA = speedArrayA[17]; break;
case 110: speedTrainA = speedArrayA[16]; break;
case 111: speedTrainA = speedArrayA[15]; break;
case 112: speedTrainA = speedArrayA[14]; break;
case 113: speedTrainA = speedArrayA[13]; break;
case 114: speedTrainA = speedArrayA[12]; break;
case 115: speedTrainA = speedArrayA[11]; break;
case 116: speedTrainA = speedArrayA[10]; break;
case 117: speedTrainA = speedArrayA[9]; break;
case 118: speedTrainA = speedArrayA[8]; break;
case 119: speedTrainA = speedArrayA[7]; break;
case 120: speedTrainA = speedArrayA[6]; break;
case 121: speedTrainA = speedArrayA[5]; break;
case 122: speedTrainA = speedArrayA[4]; break;
case 123: speedTrainA = speedArrayA[3]; break;
case 124: speedTrainA = speedArrayA[2]; break;
case 125: speedTrainA = speedArrayA[1]; break;
case 126: speedTrainA = speedArrayA[0]; break;
if (trainDir == 0) {
Serial.print(speedTrainA);
if (trainDir == 1) {
Serial.print(-speedTrainA);
dataFromI2C = 0;
/* // COMMAND PARSING
// LED OFF
case 30: digitalWrite(LED, LOW); break;
// LED ON
case 31: digitalWrite(LED, HIGH); break;
dataFromI2C = 0;
// ----------- FUNCTIONS ----------- //
void sensorRead() {
SENSOR_A1_Trigger = digitalRead(SENSOR_A1 );
if (SENSOR_A1_Trigger != 0) {
dataToI2C = 71;
// Serial.print(" |to:");
// Serial.println(dataToI2C);
else dataToI2C = 0;
void receiveI2C(int howMany) {
while (Wire.available() > 0) {
dataFromI2C = Wire.read();
// Serial.print(" |from:");
// Serial.println(dataFromI2C);
void requestI2C() {
if (dataToI2C != 0) {
Wire.write(dataToI2C); // respond with message to master
