I have seven Arduinos: one by my computer, and six of them 50 feet / 15 meters away. I'd like to use the Arduino by my computer to communicate with the Arduinos at a distance.
I was planning on sending power and I2C over a CAT-5 cable (~.19 ohm/meter, or 2.8 ohms total, or if I use each of the 4 twisted pairs as "one" cable, 1.4 ohms).
Has anyone done this before? Do you need to amplify the I2C signal on the master side? Using the Wire library, can you manually lower the I2C datarate to increase the range? Is there anything else I need to know?
