Hi everyone,
Been trying to use I2C in my acquisition setup but can't figure out what the problem is...
(this is actually extracted from this post I2C 1MHz spikes, Software Serial, capacitance, pullups and other problems... - Project Guidance - Arduino Forum but I think the title doesn't reflect the content anymore so I'm opening a new thread).
I narrowed it to very basic functions that I can't even make work, basically I'm trying to send 4 bytes over I2C (onRequest from a master) and retrieve them and print them to the serial.
Nothing really exotic, isn't it?
Here's the function for the slave that gets called onRequest:
void I2Csend()
int p=591;
Wire.write(byte(T[8]));
Serial.println(byte(T[8]));
byte x=lowByte(p);
Wire.write(x);
Serial.println(x);
byte y=highByte(p);
Wire.write(y);
Serial.println(y);
Wire.write(byte(7));
Serial.println(byte(7));
And if I look at the console, I do get : 24, 79, 2, 7 (by heart).
And this code on the master reader (that I trigger every 150mS) :
void I2C()
if(millis()>TKperiod)
TKperiod=millis()+150;
Wire.requestFrom(0x47, 4);
while(Wire.available()>0)
T[8]=Wire.read();
h=Wire.read();
l=Wire.read();
m=Wire.read();
T[m]=word(h,l);
While the I2C on the slave gets requested (since I get the serial.print in the console and they show the right figures), on the Master I get these :
7 255 255 255 0
which is in order : T[8], h, l, m, T[m]
So first of all, it seems the I2C buffer is LIFO and not FIFO (anyone can confirm me on that?).
But also, I really don't understand why only the 7 gets transmitted and none of the others...????
Oh and just one thing : on the slave arduino, there is a delay(100) in the loop due to some conversions from a thermocouple MUX shield that requires it, but as someone pointed out earlier, I2C got it's own hardware so it shouldn't be a problem... right? (seeking confirmation there ;D )
Thanks for your help!
Marc
