Hello,
I'd like to send two (or more) floats from an uno to a NodeMCU. However the float values on the master (NodeMCU) appears as 'nan' on the serial port.
Btw, for some reason, NodeMCU can only be a master. The examples of the I2C_Anthing library (GitHub - nickgammon/I2C_Anything: Arduino library to simplify reading/writing to I2C) only seem to work when the uno is a slave.
Uno
#include <Wire.h>
#include <ArduinoJson.h>
//#include <LiquidCrystal_I2C.h>
#include <I2C_Anything.h>
int bigNTCsensor = A0; // thermistor is actually at A0
int reed_sensor = A2;
volatile float temperature;
volatile float Val_reed;
Serial.begin (115200);
Wire.begin(8); /* join i2c bus with address 8 */
Wire.onRequest(requestEvent); // function to run when asked for data
delay(100);
int temperature=analogRead(bigNTCsensor);
Serial.print("Temperature big sensor is = ");
Serial.print(temperature);
Serial.println(" Celsius, ");
int Val_reed=analogRead(reed_sensor);
Serial.print("Reed sesnor value is = ");
Serial.print(Val_reed);
/* // function: what to do when asked for data
void requestEvent(int howMany)
if (howMany >= (sizeof temperature) + (sizeof Val_reed))
I2C_writeAnything (temperature);
I2C_writeAnything (Val_reed);
void requestEvent () {
struct
float temperature;
float Val_reed;
} response;
response.temperature = temperature;
response.Val_reed = Val_reed;
Wire.write ((byte *) &response, sizeof response);
} // request event
NodeMCU
#include <ESP8266WiFi.h>
#include <Wire.h>
Wire.begin(D1, D2); /* join i2c bus with SDA=D1 and SCL=D2 of NodeMCU */
// It is best to make a copy of the data while interrupts are disabled, but for now they are used directly.
Wire.requestFrom(8,6); // reqeust 6 bytes from salve Uno #8
//Wire.beginTransmission (8);
I2C_readAnything (temperature);
I2C_readAnything (Val_reed);
//Wire.endTransmission ();
delay(200);
Temperature big sensor is = nan Celsius,
Reed sesnor value is = nan
