I2C bus Connection
I have a quick question
I am looking at a Sensor that outputs a 24Bit digital signal and I am wondering if it would work with an Arduino. I know the Arduino is a 8 bit microprocessor and Idk if it would be compatible with a 24bit I2C.
here is the data sheet for the sensor, if the link doesn't work, the part# is MS5837-30BA:
http://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+SheetMS5837-30BAB1pdfEnglishENG_DS_MS5837-30BA_B1.pdfCAT-BLPS0017
I appreciate any input. Mostly looking for a yes/no, but any input is greatly appreciated.
Thank you!
Without looking at the datasheet, I2C just transfers bytes. So you will basically received 3 bytes and you need to recombine them into a 24 bit variable (32 bit will do as well as 24 bit types are scarce, just set the most significant byte to 0).
You must just check the endianness; you might receive the low byte first (read the datasheet) and when placing that in a 32 bit variable in the arduino, it might have to be placed in the high byte.
