i2c bus intermittently hangs... is there a i2c reset method/function ?
Now that Ive incorporated i2c in my robot design I now see that i2c will hang intermittently . Subsequent search find that this is a problem for people that want stable i2c connections. I have a NodeMCU master sending and recieving data from a Arduino Nano slave The hang can occur anywhere between 1 to 6 hours. I know this might seem like a long time to some but I dont know what my expectations should be.
I've tried to vary the timing from sending data every .1 seconds to every 2 seconds and the results are the same.
Is there a form of a "Wire.reset()" (or equivalent) function that can restart the I2c connection without having to do a full hald reset of the nano ?
This is what Im doing now and it works but I lose my state info on the nano and I dont want to instrument a work around before I see if ther is a way to gracefully restart i2c in software.
Or maybe should I use the I2c master Library that includes a timeout function?
Any way here is the "relevent" i2c code:
Master on NodeMCU
#include <Wire.h>
#include <i2cSimpleTransfer.h>
struct SLAVE_DATA {
    float sensor1;
    float sensor2;
    float sensor3;
    float sensor4;
    float sensor5;
    uint8_t sensor6;
    uint8_t sensor7;
    uint8_t sensor8;
    char sensor9;
    char sensor10;
    uint8_t sensor11;
    uint16_t sensor12;
void setup(void) {
    Wire.begin(D1,D2);
void loop(void)
 delay(500); // Tried different delays however nothing changes
 //do stuff...
 //   Send Data
 Wire.beginTransmission(8); /* begin with device address 8 */
 Wire.write(rcmd);  /* sends hello string */
 Wire.endTransmission();    /* stop transmitting */
delay (100);
 //  Read Data
 delay(100);
 Wire.requestFrom(8, sizeof slave_data ); /* request & read data of size 13 from slave */
 if ( Wire.available() == sizeof(slave_data) ) {
        i2cSimpleRead(slave_data);
delay (100);
Slave on Nano
#include <Wire.h>
struct SLAVE_DATA {
    float sensor1;  // use specific declarations to ensure communication between 16bit and 32bit controllers
    float sensor2;
    float sensor3;
    float sensor4;
    float sensor5;
    uint8_t sensor6;
    uint8_t sensor7;
    uint8_t sensor8;
    char sensor9 = '0';
    char sensor10;
    uint8_t sensor11;
    uint16_t sensor12;
SLAVE_DATA slave_data;
  Wire.begin(8);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
  delay(100);
void loop(void)
// do stuff...
  void receiveEvent(int howMany) {
   while (0 <Wire.available()) {
     char c = Wire.read();
     rcmd=c;
void requestEvent() {
  i2cSimpleWrite(slave_data);
Your sketches are slightly adjusted/modified; upload them and observe the results:
Master Codes:
#include <Wire.h>
struct SLAVE_DATA
    float sensor1;
    float sensor2;
    float sensor3;
    float sensor4;
    float sensor5;
    uint8_t sensor6;
    uint8_t sensor7;
    uint8_t sensor8;
    char sensor9;
    char sensor10;
    uint8_t sensor11;
    uint16_t sensor12;
void setup(void)
    Wire.begin(D1, D2);
void loop(void)
 Wire.write(0x01); //(rcmd);  /* sends hello string */
Slave Codes
#include <Wire.h>
struct SLAVE_DATA
    float sensor1;
    float sensor2;
    float sensor3;
    float sensor4;
    float sensor5;
    uint8_t sensor6;
    uint8_t sensor7;
    uint8_t sensor8;
    char sensor9;// = '0';
    char sensor10;
    uint8_t sensor11;
    uint16_t sensor12;
  Wire.begin(8);
  slave_data.sensor09 = '0';
void loop(void)
     byte c = Wire.read();
void requestEvent(int howMany)
Thank you Ill try it !
