i2c bus on arduino nano and Wire library problem
I've been playing some time with I2C bus on the arduino, without a lot of luck so far.
I just found the I2C library from "fat16lib", found at (can't post)
Everything was working in the minut.
I'm so asking a really simple question.
What is the "Wire" library equivalent to this short source code, to read the register on an i2C componant (an AMIS-30624 stepper driver) :
// read the GetfullStatus1
    if (rtc.start(add | I2C_WRITE)) {  // send a START on the i2c bus, for slave address "add" which is 0xC0
     rtc.write(0x81); // ask for the register at address 0x81 in the ship buffer
   if (rtc.restart(add | I2C_READ)) { // reconnect to the i2c bus and read from the slave
      Serial.print("full Add read: ");
      Serial.println(add, BIN);
      for (int i=0 ; i<8 ; i++) {    // the resgister is 8 bytes long, scroll through it
        readbuf=0;
        // read the 8 byte buffer
        readbuf=rtc.read((i == 7));   // use read(0) to scroll through the buffer. Send rend(1) when last buffer read
        Serial.print(i);
        Serial.print(" -- ");
        Serial.println(readbuf, BIN);
    rtc.stop();
This is the result on the console :
full Add read: 11000000
0 -- 11100000
1 -- 0
2 -- 0
3 -- 0
4 -- 100000
5 -- 10000
6 -- 11111111
7 -- 0
With the wire, I tried without success something like :
  Wire.beginTransmission(0xC0); // transmit to device address 0xC0
  Wire.send(0x81);        // ask for buffer 0x81
  Wire.endTransmission();    // stop transmitting
    Wire.requestFrom(0xC1, 1);    // request 1 bytes from slave
    c = Wire.receive(); // receive a byte as character
    Serial.print ("read ");
    Serial.print (0xC1,BIN);
    Serial.print (" = ");
    Serial.println(c,BIN);         // print the character
I must be missing something...
Whatever, the library from "fat16lib" is working fine, and you can choose between hardware i2c or software i2c on the arduino, which may be usefull for some of you.
Thanks for your forthcoming help.
Prune
URL I couldn''t post earlier is New i2c libraries with 'softi2c' - adafruit industries
Is my chip also support a 0x00 broadcast address, I had a try with this code, with success :
#define Read     B00000000
#define Write    B00000000
#include <Wire.h>
int c = 0x00;        // set read buffer to 0
int chipbuffer=0x81;
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Serial.println("startup...");
  delay(100);
  Wire.beginTransmission(Write); // transmit to slave Write address
  Wire.send(chipbuffer);        // sends code 0x81
  Wire.requestFrom(Read, 8);    // request 8 bytes from slave
  if (Wire.available()) {
      c=0;
      c = Wire.receive();
      Serial.print (Read,BIN);
  Serial.println("done...");
  delay(5000);
And the result :
startup...
read 0 = 11100000
read 0 = 0
read 0 = 0
read 0 = 0
read 0 = 100000
read 0 = 10000
read 0 = 11111111
read 0 = 0
done...
The first return line should be "111" + the 5 address bit.
Then the address of the ship is :
"11"+5 address bit + R/W bit
In my case, address is : 1100000(0/1) for writing/reading.
If I set this in the Read and Write variable (either the same address 11000000 or set the read address as 11000001), then I have no answer from the slave.
What the hell ?
