Hi everybody !
I've got some issues with one of my sensors : a MAX30100, which is a heart rate monitoring sensor.
It communicates with Arduino through I2C protocol.
We can access various register from 0x00 to ...
I want to access the FIFO register, which stores Infrared and Red photo diode values.
First, i've tested the address with this code :
#include <Wire.h>
Wire.begin();
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 0; address <= 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(500); // wait 8 seconds for next scan
It responds well, giving me the 0x57 address i've expected.
The write / read addresses in MAX30100 datasheet are 0xAE and 0xAF
0xAF = 0b10101111
0xAE = 0b10101110
And
0x57 = 0b1010111 so it's great.
Then, i want to access the 0x00 = interrupt status in order to test if the connection is working.
Normally, the datasheet says that about the 0x00 register.
So bits 2-3-4 should be 0 and the only respond i get with this code :
# include <Wire.h> // La bibliothèque Wire gère l'I2C
#define MODE_CONFIGURATION (0x06) //Définition des différentes adresse pour les modes utilisés
#define FIFO_DATA_REGISTER (0x05) // Adresse du FIFO_DATA (là où sont stockées les données)
#define WRITE_POINTER (0x02) // adresse du registre FIFO WRITE POINTER
#define READ_POINTER (0x04) // Adresse du registre FIFO READ POINTER
#define INTERRUPT_STATUS (0x00) // Adresse du registe Interrupt Status
#define MASK (0x02) // Masque pour le Bit HR_RDY
#define MAX (0x57) // Adresse du capteur en mode écriture
int Number_Of_Sample = 0; // Nombre de samples disponibles dans la mémoire FIFO
int tableau[16]; // Tableau dans lequel les donnée seront stockées
int write_pointer = 0;
int read_pointer = 0;
void setup(){ // Initialisation des ressources
Serial.begin(9600); // Initialisation Terminal Série
Wire.begin();
pinMode(SDA, INPUT);
pinMode(SCL, INPUT);// Initialisation I2C
void loop(){
Wire.beginTransmission(0x57);// MAX30100 ID en mode READ
Wire.write(0x00);
Wire.endTransmission(false);
Wire.beginTransmission(0x57); // lecture registre Interrupt status, INT doit passer en LOW si POWER_READY = 1
byte HR_RDY = Wire.read();
Serial.println(HR_RDY); //La réponse doit être xx1xxxxx.
Wire.endTransmission(); //restart
//STOP
is -1
Which is 255 in byte, which is 0b11111111
I've got several hypothesis with that :
- -1 is an error message and the communication with my sensors doesn't works (buffer is empty)
- I2C bus uses to high voltage for my sensor :
But it doesn't fit with the first code that returns 0x57...
Hardware side, i've placed my QFN on a PCB i made, the connections are good but my RED LED doesn't blink when i test it with an ohm meter (between GND and RED_PWR, GND and VDD pins)
Thanks a lot for your help !
