I2C bus - sending 2 numbers higher than 255
I would like to send 2 number higher than 255 between Master and Slave using the I2C bus.
Send 1 number is working perfect.
I hope for some help to change the code. I think the problem is the slave code.
I am using Arduino Uno (2 of course)
// Slave com 7
#include <Wire.h>
int VinL;
int VinR;
byte dataSend[5];
void setup(){
Wire.begin(10);
Wire.onRequest(requestEvent);
void loop(){
   VinL = 1020;
   VinR = 980;
delay(100);
void requestEvent(){
dataSend[0] = (VinL >> 8) & 0xFF;
dataSend[1] = VinL & 0xFF;
dataSend[2] = (VinR >> 8) & (0xFF * 2);
dataSend[3] = VinR & (0xFF * 2);
dataSend[4] = 2;
Wire.write(dataSend,3);
This is the master code
// Master - com 6
#include <Wire.h>
volatile byte dataGet[5];
int VinL;
int VinR;
void setup(){
Wire.begin();
void loop(){
 delay(2000);
 hentData();
 Serial.println(VinL);
 Serial.println(VinR);
 Serial.println(dataGet[4]);
 Serial.print("\n");
void hentData(){
   Wire.requestFrom(10, 5);                             // Request data
   for (byte i=0; i<5; i++){dataGet[i] = Wire.read();}  // Reading data
   VinL = dataGet[0];VinL = VinL << 8 | dataGet[1];
   VinR = dataGet[2];VinR = VinR << 8 | dataGet[3];
These lines are wrong:
You just need to do exactly like the first number
dataSend[2] = (VinR >> 8) & 0xFF;
dataSend[3] = VinR & 0xFF;
It may be easier to use a structure
Screen shot:
Master Sketch (NANO):
// Master - com 6
#include <Wire.h>
byte dataGet[5];
int VinL;
int VinR;
  Wire.begin();
  delay(2000);
  hentData();
  Serial.println(dataGet[4]);  //should show 2
  Serial.println();//("\n");
void hentData()
  for (byte i = 0; i < 5; i++)
    dataGet[i] = Wire.read(); // Reading data higher byte first
  VinL = dataGet[0] << 8 | dataGet[1];
  //VinL = VinL << 8 | dataGet[1];
  VinR = dataGet[2] << 8 | dataGet[3]; // VinR = VinR << 8 | dataGet[3];
Slave Sketch (MEGA):
// Slave com 7
#include <Wire.h>
int VinL;
int VinR;
byte dataSend[5];
  Wire.begin(10);
  VinL = 1020;  //03FC
  VinR = 980; //03D4
  delay(100);
void requestEvent()
  dataSend[0] = highByte(VinL); //sending higher byte first (VinL >> 8) & 0xFF;
  dataSend[1] = lowByte(VinL);//VinL & 0xFF;
  dataSend[2] = highByte(VinR);//sending high byte first(VinR >> 8) & (0xFF * 2);
  dataSend[3] = lowByte(VinR);//VinR & (0xFF * 2);
  dataSend[4] = 0x02;
  Wire.write(dataSend, sizeof(dataSend));//3);
I am very happy to have a reply fast and a fully working sketch.
The suggestion are working perfect.
Thank you very much GolamMostafa and blh64
Perhaps a small note regarding the application for the solution.
I am working on a soundcard interface for measuring specifications on audio amplifiers.
The Arduino part.
Arduino ATtiny84 (master and slave)
Measuring 4 analog inputs (2 channels input and 2 channels output)
and sending these information to Arduino Nano.
ATtiny 84 receives 6 bytes of switch positions from the Nano.
Arduino Nano (Master and slave)
Monitoring 6 switches and send the information to ATtiny 84 which then control switching relays.
Receiving the 4 analog measured inputs and outputs
The mesured data are displayed on 2 OLED displays (one for input and one for output)
The display also show the settings of the switches.
The I2C databus handle all the communication and saves a lot of cables :slight_smile:
...... and the project is a nice challange.
