I2C bus usage through arduino IDE
Hello,
I am using an ESP32 azure IoT kit and i would like to have access to the sensors' data . I am trying to make it through the I2C bus. Although, the scanning proccess on I2C does not detect any device.
I am coding in arduino IDE. Is there any advices?
Thank you!
In that case most probably the wiring is wrong. As you failed to post a wiring diagram of your setup, we cannot help you further. Also post a link to the hardware you're trying to connect (sensor).
