i2c clock trouble
I am trying to make a clock, seems easy enough. Everything works by itself, alone. But the code seems to hang when I introduce the RTC (DS1307) library AND the tm1637 library. When running the two things together the code just hangs. so into troubleshooting
Trying to get something to work I realized that the RTC would work and send 22 as an hour (at 10pm) but once I hooked one of the wires (clock OR data) the RTC would go to 165 only and every time.
is something not i2c? I am confused on why it changes, when the device addresses are not the same.
I am using adafruit RTClib and TM1637 library from Avishay
The device is a simple i2c connection with 3.3k resistor and a 100nf cap between vcc and ground.
please help! Ill buy a new module if I need to
#include <Wire.h>
#include <TM1637Display.h>
#include "RTClib.h"
RTC_DS1307 RTC;
TM1637Display display(SCL, SDA);
int hr1, hr2, min1, min2;
    Wire.begin();
    RTC.begin();
     if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
  DateTime now = RTC.now();
  uint8_t data[] = { 0xff, 0xff, 0xff, 0xff };
  uint8_t blank[] = { 0x00, 0x00, 0x00, 0x00 };
  display.setBrightness(0x0f);
  // All segments on
  display.setSegments(data);
  delay(5000);
  hr1 = (now.hour() / 10);
  hr2 = (now.hour() % 10);
  min1 = (now.minute() / 10);
  min2 = (now.minute() % 10);
  display.clear();
  data[0] = display.encodeDigit(hr1);
  data[1] = display.encodeDigit(hr2);
  data[2] = display.encodeDigit(min1);
  data[3] = display.encodeDigit(min2);
  delay(5000);
Please edit your post to change the quote tags to code tags.
I have no idea what you mean by this:
Please post a hand drawn wiring diagram (not Fritzing), labeling all the connections with pin numbers.
you think it is, until you try.
Build a GPS-controlled Clock
Build an AccurateGPS-Controlled Clock: Step by Step
I think you pointed me towards the solution with these guides. I will have to test later.
Interface interpretationMicroprocessor data realize the communicationwith TM1637by means of two–wire bus interface
(Note: The communication method is not equal to 12C bus protocol totally because there isno slave address).
From https://www.mcielectronics.cl/website_MCI/static/documents/Datasheet_TM1637.pdf
You should use different pins for I2C (RTC) and the TM1637.
