I2C com. between NodeMCU ( ESP8266 ) and Arduino MEGA
Hi @ all,
I have a problem with I2C communication.
Situation:
NodeMCU ( ESP8266 ) as Master ( Pin D1 and D2 )
Arduino MEGA as Slave ( Pin SDA20 and SCL21 )
Tested with and without PullUp resistors on both lines.
I can send a message from the Master to the slave without any Problems.
But if I try to send something from Slave to Master, the Master receives nothing.
Codesnippet from Master:
Setup()
Wire.begin();
//Wire.setClockStretchLimit(40000); // If I comment in, nothing change
bool sent = false;
loop()
int test = Wire.available(); // To see is something coming from Slave
Serial.println(test);
// The following message will only send once
if(!sent){
Wire.beginTransmission(SLAVE_ADDRESS);
Wire.write(“Hallo”);
Wire.endTransmission();
sent = true;
Codesnippet from Slave:
Setup()
Wire.begin(SLAVE_ADDRESS);
Wire.onReceive(receiveI2C);
void receiveI2C(int howMany)
String message = “”;
while (Wire.available() > 0) {
char c = Wire.read();
message += c;
Wire.write(“Danke”);
So the slave receives the word “Hallo” and send back “Danke” to Master.
But the Master never receive something.
The output of Wire.available(); on Master is always 0.
Any Idea why ?
Regards
Stefan
I'm having the same problem... Hope you'll find the answer...
i made it work with this examples: http://www.electronicwings.com/nodemcu/nodemcu-i2c-with-arduino-ide https://thewanderingengineer.com/2015/05/06/sending-16-bit-and-32-bit-numbers-with-arduino-i2c/
but, it was very tricky sometimes depending of the data types you are sending.
Finally a used this super helpful examples: https://github.com/Scott216/I2C-Examples
you can send some packets together using different data types only in one request.
