I2C communication atmega
Coding for atmega2560
Maybe
Please help us to help you. Show a circuit diagram of your I2C bus. What does the I2C_scanner tell you?
Welcome @anon57196577
I'm not quite sure how this relates to to Interfacing w/ Software on the Computer and hence this has been moved to amore suitable location on the forum.
Have you checked your favorite search engine? E.g. Arduino ADS1113 - Google Search
An ADS1113 is the stripped-down version of the ADS1115, with fixed PGA (1/1) etc.
Plenty examples and code for the ADS1115 out there.
Try Adafruit.
Leo..
i2c_scanner we didn't check. We embedded the Atmega2560 and ADS1113 in PCB. By using the Aurdino board and bootloader we will put the code in ATMEGA2560. By the sensor, through the ADC data should come to Microcontroller again. That needs to be stored in SD card.
Why not? It's the first problem spotter.
