I2C Communication between Master and Slave
Hi everyone
Basically, I am trying to make the Slave arduino the sender and the Master arduino the receiver. I have implemented an Ultrasonic Sensor onto the Slave arduino and it is outputting the distance measurements successfully onto the CLI of the Slave Arduino. However, I would like the Slave arduino to send the Ultrasonic measurements to the Master Arduino. I have tried getting it to work since the past couple of weeks but my attempts have not been successful. I can send basic messages such as 'Hello' but not sensor readings..
I'm currently at work so if you would like both the master and slave Arduino codes I can post them once I get home. Thanks in advance. :slight_smile:
Yes, we'll need to see the code to help you.
While you’re at it, post the “Hello” sketch that does work too.
Hi, apologies for the delay. Here is the code which works and sends the “Hello” message across.
Master Code
// Include the Arduino Wire Library for I2C
#include <Wire.h>
// Define Slave I2C Address
#define SLAVE_ADDR 9
// Define Slave answer size
#define ANSWERSIZE 5
const int ledPin = 13;
const int ldrPin = A0;
int pressureAnalogPin = 1;
int pressureReading;
int noPressure = 5;
int lightPressure = 100;
int mediumPressure = 200;
  // Initialize I2C communications as Master
  Wire.begin();
  // Setup serial monitor
  Serial.begin(9600); // This is the baud rate
  Serial.println("I2C Master Demonstration"); // Let's test this..
  pinMode(ledPin, OUTPUT);
  pinMode(ldrPin, INPUT);
  delay(50);
  Serial.println("Write data to slave");
  // Write a character to the Slave
  Wire.beginTransmission(SLAVE_ADDR);
  Wire.write(0);
  Wire.endTransmission();
  Serial.println("Receive data");
  // Read response from Slave
  // Read back 5 characters
  Wire.requestFrom(SLAVE_ADDR,ANSWERSIZE);
  // Add characters to string
  String response = "";
  while (Wire.available()) {
    char b = Wire.read();
    response += b;
  // Print to Serial Monitor
  Serial.println(response);
  int ldrStatus = analogRead(ldrPin);
  if (ldrStatus <= 200) {
    digitalWrite(ledPin, HIGH);
    Serial.print("It is Dark, Turn on the LED : ");
    Serial.println(ldrStatus);
  else {
    digitalWrite(ledPin, LOW);
    Serial.print("It is Bright, Turn off the LED : ");
  pressureReading = analogRead(pressureAnalogPin);
  Serial.print("Pressure Pad Reading = ");
  Serial.println(pressureReading);
  if (pressureReading < noPressure) {
    Serial.println(" - No pressure");
  } else if (pressureReading < lightPressure) {
    Serial.println(" - Light Pressure");
  } else if (pressureReading < mediumPressure) {
    Serial.println(" - Medium Pressure");
  } else{
    Serial.println(" - High Pressure");
Slave Code
#include <Servo.h>
// Include Arduino library for I2C
#include <Wire.h>
// Define string with response to Master
String answer = "Hello";
Servo servo;
int trig=8;
int echo=9;
int duration;
float distance;
float meter;
int buzz = 10;
  // Initialize I2C communications as Slave
  Wire.begin(SLAVE_ADDR);
  // Function to run when data requested from master
  Wire.onRequest(requestEvent);
  // Function to run when data received from master
  Wire.onReceive(receiveEvent);
  // Setup Serial Monitor
  Serial.println("I2C Slave Demonstration");
  servo.attach(6);
  pinMode(trig, OUTPUT);
  digitalWrite(trig, LOW);
  delayMicroseconds(2);
  pinMode(echo, INPUT);
  delay(6000);
  pinMode(buzz, OUTPUT); // Buzzer is the digital one.
  Serial.println("Distance:");
void receiveEvent() {
  // Read while data received
  while (0 < Wire.available()) {
    byte x = Wire.read();
  Serial.println("Receive event");
void requestEvent() {
  // Setup byte variable in the correct sizw
  byte response[ANSWERSIZE];
  // Format answer as array
  for (byte i=0;i<ANSWERSIZE;i++) {
    response[i] = (byte)answer.charAt(i);
  // Send response back to Master
  Wire.write(response,sizeof(response));
  Serial.println("Request event");
  // Time delay in loop
  delay(50);
  int i=20; // This can be set to any value to change the frequency.
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  digitalWrite(trig,LOW);
  duration = pulseIn(echo, HIGH);
  distance = duration/58;
  Serial.print(distance);
  Serial.print("cm");
  Serial.print("\n"); // This is required to calculate the distance in centimeters.
  if(distance<=30 && distance >=1) // The buzzer will start buzzing if the distance is between 1 to 30cm.
  i=distance*i; // This is the main algorithm.
  digitalWrite(buzz, HIGH);
    delay(i); // So the delay between switching will change according to the distance.
  digitalWrite(buzz, LOW);
    delay(i);
  delay(10);
I hope the way I posted the code is okay, it’s my first time posting here so sorry if anything isn’t correct, thanks.
The way you posted the code is perfect. Thanks!
Now please post the code that is not working.
Great! well, I’m getting an error on the Slave sketch saying that the ‘receiveEvent’ was not declared in this scope…
Here is my code for the Slave Arduino:
#include <Servo.h>
#include <Wire.h>
Servo servo;
int trig=8;
int echo=9;
int duration;
float distance;
float meter;
int buzz = 10;
  Wire.begin(4); // Join I2C bus with address #4
  Wire.onReceive(receiveEvent); // register event
  servo.attach(6);
  delay(6000);
  delay(50);
  Serial.print("cm");
    delay(i);
  void receiveEvent(int howMany)
    while(1 < Wire.available()) // Loop through all but the last
      char c = Wire.read(); // Receive byte as a character
      Serial.print(c); // Print the character
    int x = Wire.read(); // Receive byte as an integer
    Serial.println(x);
  delay(10);
You put the definition of your receiveEvent function inside the loop function. You can see this by the way the function definition is indented. You can’t define one function inside another function.
:o O wow, didn't see that! its done uploading now, thanks to you. I'm going to have a play with it and try to get it sending the distance measurements then come back if I encounter any other errors. Appreciate that!
You’re welcome. I’m glad if I was able to be of assistance.
I hope it will work correctly now, but if not we’re always here to help.
Enjoy!
Per
Okay, It uploaded successfully but it doesn’t seem to be outputting anything… It is giving me the same outputs I had before adding in this code which is odd.
Master Code
#include <Wire.h>
int noPressure = 5;
  Wire.begin();
  Wire.requestFrom(2, 6); // Request 6 bytes from slave device.
  while (Wire.available()) // Slave may send less than requested.
    float distance = Wire.read(); // Receive a byte as a float
  else {
Slave Code
#include <Servo.h>
#include <Wire.h>
Servo servo;
int trig = 8;
int echo = 9;
int duration;
float distance;
float meter;
int buzz = 10;
  servo.attach(6);
  delay(6000);
  delay(50);
  int i = 20; // This can be set to any value to change the frequency.
  distance = duration / 58;
  Serial.print("cm");
  if (distance <= 30 && distance >= 1) // The buzzer will start buzzing if the distance is between 1 to 30cm.
    i = distance * i; // This is the main algorithm.
    delay(i);
  while (1 < Wire.available()) // Loop through all but the last
    float distance = Wire.read(); // Receive byte as a character
    Serial.print(distance); // Print the distance values
  Serial.println(x);
  delay(10);
Try the following codes which are modifications of your Post#9. (There are many things wrong both in Master and Slave codes of Post#9.)
Master Code:
#include <Wire.h>
int noPressure = 5;
union
   float distance;                     //distance
   byte myData[4];
}data;
  Wire.begin();
  Wire.requestFrom(SLAVE_ADDR, 4); // Request 4 bytes (32-bit binary32 data of float distance from slave
  for(int i=0; i<4; i++)
        data.myData[i] = Wire.read();  //
   Serial.println(data.distance, 2);   //Serial Monitor shows distance sent by Slave (2-digit after decimal point)
  //while (Wire.available()) // Slave may send less than requested.
   // float distance = Wire.read(); // Receive a byte as a float
    //Serial.print(distance);
  else {
Slave Codes:
#include <Servo.h>
#include <Wire.h>
Servo servo;
int trig = 8;
int echo = 9;
int duration;
float distance;
float meter;
int buzz = 10;
union
   float x;                     //x will be replace by distance
   byte myData[4];
}data;
  Wire.begin(SLAVE_ADDR); //(4) // Join I2C bus with address #4
  //Wire.onReceive(receiveEvent); // register event
  Wire.onRequest(sendEvent);
  servo.attach(6);
  delay(6000);
  delay(50);
  data.x = distance;
  Serial.print("cm");
    delay(i);
void sendEvent()//receiveEvent(int howMany)
   Wire.write(data.myData, sizeof(data.myData));//float distance goes to Master as 32-bit binary32 data
  Serial.println(x);
  delay(10); */
Thank you, brother! It is working now.
Thank you Pert and Mustafa.
