Hi I'm working on a project to send data and receive data through I2C communication between two NodeMCU. I tried a lot of code but I'm not getting the values in both.
Kindly help me to get solution for this
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project.
Please show the code that you tried (for both master and slave). Don't forget to use code tags (the </>
button) when posting code.
I'm not really familiar with the NodeMCU so probably will not be able to help further.
the esp8266 Wire library doesn't work in slave mode
