I2C Communication / debounce / interrupt errors
Hi all good morning to every body,
SCENARIO:
  • 2 arduino’s uno connected via i2c on analog 4 (SDA) and analog 5(SCL)
  • On the Master I’ve connected a button digital pin 2
  • On the slave there is connected led on digital pin 12
    Every thing is working, when I press the button send via bus the HIGH state and the led is turned on. When I press the button again send the LOW and the led is turned off.
    Well the problem is that when I’ve pressed the button and sent data over i2c on the slave I do a serial out in this way (correct me if wrong) i see the state in that moment and i can see a lot’s of value sent from the button and not only one. So, I’ve looked for that internet and I’ve put in place a adjust my code with a bounce library it’s a little bit better but not optimal … Also I’ve seen that is possible use interrupt but there I don’t understand if after the interrupt is switch off or if necessary detach it … and also I’ve seen that is possible install this CMOS mc14490 for fix the debounce issues …
I did a try with the interrupt configuring it but didn’t work … ;-(
My intentions if is possible is doing everything from software and I think that maybe the better solution is use the interrupt …
please if there is someone that already encountered this kind of issues please let me know :wink:
Thx for the help
Andrea
Please post your code
My intentions if is possible is doing everything from software and I think that maybe the better solution is use the interrupt ...
I disagree. Interrupts are complex to use and understand. If you can't get simple I2C communications to work when polling the switch state, the chances of getting it to work when using an interrupt are even lower.
Get the I2C part working with polling before you even consider interrupts.
And ditto the request to post your code.
For the debounce check - http://arduino.cc/playground/Code/Bounce -
Hi Guys, I will post the exact code this evening when i will come back to work :-)
Thanks for the support,
Andrea
MASTER CODE:
#include <Bounce.h>
#include <Wire.h>
#define buttonPin 2 // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
int buttonState = LOW; // variable for reading the pushbutton status
Bounce bouncer = Bounce( buttonPin,5 );
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
Wire.begin(); // join i2c bus (address optional for master)
// Update the debouncer
bouncer.update ( );
int in = bouncer.read();
if (in == HIGH)
if (buttonState ==LOW)
buttonState = HIGH;
buttonState = LOW;
// turn LED on:
digitalWrite(ledPin,buttonState);
Wire.beginTransmission(4); // transmit to device #4
Wire.send(buttonState);
Wire.endTransmission();
SLAVE CODE :
#include <Wire.h>
const int ledPin = 12; // the number of the LED pin
Wire.begin(4); // join i2c bus with address #4
Wire.onReceive(receiveEvent); // register event
Serial.begin(9600); // start serial for output
delay(3000); //Wait 2 Second before re-excute
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
//while(1 < Wire.available()) // loop through all but the last
int x = Wire.receive(); // receive byte come un integer
if (x == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
Serial.println(x);
else {
// turn LED off:
digitalWrite(ledPin, LOW);
Serial.println(x);
thx for the support Andrea
                buttonState = HIGH;
                buttonState = LOW;
could be written as
buttonState = !buttonState;
That leaves loop() on the master:
  bouncer.update ( );
     if (in == HIGH)
    // turn LED on:
which makes it obvious that you are sending data on every pass through loop, not just when the button is pressed. I think it is obvious what you need to do.
I've did the code improvement that you have suggest to me ... But now How i can do for the send only one data when I've press the button one time so mainly time the is not switch off. My problems is not the loop but the when I press the button I send out a lot of date and only 1 when is pressed one time and 0 when is pressed again ... maybe it's that you define "obvious" ;-) ... put a condesator ?or something like that ?
thx Andrea sorry but I'm very new devoloper with arduino ;-)
How i can do for the send only one data when I’ve press the button one time
If you want to send data only once for each button press, the Bounce library is not the right library to be using. The Button library would be a better choice. It has a method, uniquePress() that returns true only one time per button press.
Each time uniquePress() returns true, send the message:
Button sw(pin, PULLUP);
   if(sw.uniquePress())
      // Turn on the LED and send the message
If you want to send different messages when the switch is pressed and when it is released, you can use the isPressed() and wasPressed() methods to determine if the switch is pressed and was not (send the pressed message) or was pressed and is not pressed (send the released message).
Thank ;-) for your quick reply ;-) I've change the code like a your indication and now seems better thanks :-) but is not perfect some times still to lose the pressed ... :-( and I've to click a button several time for switch on or off the led ... do you think that is only a master issues or I can Improve also the Slave ? REgards Andrea
We need to see your current code.
3000 milliseconds is not 2 seconds, and the delay is completely unnecessary.
hi i've putted 50ms like llike delay and now it's perfect thx
Andrea
Put the 50ms delay where?
Adding delay() is likely NOT the best solution.
Thank you PaulS,
Sorry to bounce-up (pun intended) this thread but this Button library you mentioned was very useful for me. I already had some working code using Bounce with .fallingEdge but liked yor suggestion better, with 16 PULLDOWN Buttons monitoring pins 2-13 & A0-A3. Much more elegant and saves some memory space. 8)
I built a 16 sensor input module for the tracks in my model railroad using an Arduino UNO with a ScrewShield from Adafruit.
Button sensor[16] =
    Button(2, PULLDOWN), Button(3, PULLDOWN), Button(4, PULLDOWN), Button(5, PULLDOWN),
    Button(6, PULLDOWN), Button(7, PULLDOWN), Button(8, PULLDOWN), Button(9, PULLDOWN),
    Button(10, PULLDOWN), Button(11, PULLDOWN), Button(12, PULLDOWN), Button(13, PULLDOWN),
    Button(14, PULLDOWN), Button(15, PULLDOWN), Button(16, PULLDOWN), Button(17, PULLDOWN)
      //detect sensor triggering only once
      value = sensor[pin-2].uniquePress();      // arrays start at 0 index so, use pin - 2
      abkonInputStates = abkonInputStates | ( value << (pin - 2) );  // set corresponding input pin bit
I have an “¡Hola amigos!” thread on the General Discussion forum, introducing me, in case you want to take alook at it:
http://arduino.cc/forum/index.php/topic,75690.0.html
Thank you for telling us about the Button library. :slight_smile:
