Hello,
I would like to establish a 2way communication between 2 Arduino Uno.
Each Arduino can receive commands from the other.
On each Arduino there is a led and a button.
This is the code used on to make one way communication: the command is sent from Arduino A to Arduino B : when the button on Arduino A is pressed, the led on Arduino B is switched ON.
The code below works. The string "TEST" is correctly received on Arduino B. The problem is that the led on Arduino B goes on and off one time very quickly instead of remaining ON during 5 seconds. Same problem if I replace it with a buzzer.
I have tested with different Arduino's but same problem.
Does somebody has an idea ?
Thanks for your time.
Mario
Code on Arduino A
#include <Wire.h>
const int pldr = 3; // led
const int pbut = 4; // button
int bs1 = 0;
Wire.begin();
pinMode(pldr,OUTPUT); // led
pinMode(pbut,INPUT); // button
bs1 = digitalRead(pbut);
if (bs1 == HIGH) {
Wire.beginTransmission(4);
Wire.write("TEST");
Serial.println("Command sent");
Wire.endTransmission();
Code on Arduino B
#include <Wire.h>
String readString;
Wire.begin();
Wire.onReceive(receiveEvent);
void receiveEvent(int howMany)
readString = "";
while(Wire.available()){
readString += (char)Wire.read();
delay(200);
delay(200);
if(readString == "TEST"){
digitalWrite(pldr, HIGH);
[b]delay(5000);[/b]
digitalWrite(pldr, LOW);
