I was hoping you all could help with a question I have about writing and reading from I2C enabled device. The device I'm hoping to read data from is the PD controller "FUSB302B". I would like to write the MEASURE register which address is "04h". My background in firmware isn't very strong so I'm not to sure how that address correlates with the hex value you put into Wire.write(). Below is my code:
byte data;
Wire.beginTransmission(34); //0x22 to decimal
Wire.write(byte("address 04h to hex?)); // sends instruction byte
Wire.endTransmission();
Wire.requestFrom("address 04h to hex?", 1);
if(Wire.available())
data = Wire.read();
Serial1.print(data);
What have you done ? Are you using real tabs in the source code ? How did that happen ? Are you also wearing a top hat and a cane when you go outside ? Can you change your editor settings and run a tool on all your *.ino files to change the real tabs into spaces ?
The requestFrom() reads from a I2C address, but you got the global idea.
Don't keep the I2C bus busy all the time, add a delay in the loop().
The datasheet shows a "repeated start".
Can you find a I2C Scanner sketch, let it run to see if it finds its I2C address.
Then you know that the I2C bus is working.
Use the found I2C address in your sketch.
Then try to read its Device ID.
Wire.beginTransmission(0x22); // I2C address
Wire.write( 0x01); // Register address
Wire.endTransmission(false); // false for a repeated start
int n = Wire.requestFrom(0x22, 1); // request 1 byte
if( n == 1) // received the same amount of bytes that was requested ?
data = Wire.read();
Serial1.print("0x");
Serial1.println(data, HEX);
Serial1.println("Error, can't see the chip");
delay( 1000);
If that Device ID makes sense, then you know that you can read from a register.
Writing data to register 0x04 is like this:
Wire.write( 0x04); // Register address
Wire.write( 0x33); // The data. I just gave an example, don't use 0x33
Haha, I edit in Microchip Studio and use Ardunio core.
The device address is 0x22 (actually confirmed with the I2c scanner so great tip).
I just get confused when it comes to datasheets sometimes (my background is mostly system and board design) so thank you for the clarification.
So the short answer is when a datasheet stataes the address of the register is 0ah, it's 0x0a in hex (a being a varible in this situation).
