I2C Communication
I am trying to carry out an I2C communication between arduino and esp. In this case I want to send 6 messages from the slave to the master, but the communication is corrupted from the 5. What is happening? The messages consist of 8 characters where 7 are the message and the 8th use to indicate the end of it.
//Slave part
#include <Wire.h>
String m0_I2C;
String m1_I2C,m2_I2C,m3_I2C,m4_I2C,m5_I2C;
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onRequest(requestEvent); // register request event
  Serial.begin(9600);           // start serial for debug
  float m0=22.56;
  float m1=80.0;
  float m2=42.9;
  float m3=200.58;
  float m4=200.0;
  float m5=70.0;
  m0_I2C=floatToString_I2C(m0, 7, 2, true);
  m1_I2C = floatToString_I2C(m1, 7, 2, true);
  m2_I2C=floatToString_I2C(m2, 7, 2, true);
  m3_I2C=floatToString_I2C(m3, 7, 2, true);
  m4_I2C=floatToString_I2C(m4, 7, 2, true);
  m5_I2C=floatToString_I2C(m5, 7, 2, true);
  Serial.println (m0.c_str());
  Serial.println (m1.c_str());
  Serial.println (m2_I2C.c_str());
  Serial.println (m3_I2C.c_str());
  Serial.println (m4_I2C.c_str());
  Serial.println (m5_I2C.c_str());
  delay(2000);
// function that executes whenever data is requested from master
void requestEvent() {
  Wire.write(m0_I2C.c_str());
  Wire.write(m1_I2C.c_str());
  Wire.write(m2_I2C.c_str());
  Wire.write(m3_I2C.c_str());
  Wire.write(m4_I2C.c_str());
  Wire.write(m5_I2C.c_str());
String floatToString_I2C( float n, int l, int d, boolean z){
  char c[l+1];
  char s[6];
  String f;
  dtostrf(n,l,d,c);
  f=String(c);
  if(z){
    f.replace(" ","0");
  f.concat("/");    // 8th
  return f;
//Master part
#include <Wire.h>
  Serial.begin(9600); /* begin serial for debug */
  Wire.begin(5, 4); /* join i2c bus with SDA=D1 and SCL=D2 of NodeMCU */
  Wire.beginTransmission(8); /* begin with device address 8 */
  Wire.write("Hello Arduino");
  Wire.endTransmission();
  Wire.requestFrom(8, 50);  //
  String m0 = "";
  String m1 = "";
  String m2 = "";
  String m3 = "";
  String m4 = "";
  String m5 = "";
  int i=0;
  while (i<50){
    i++;
    char c=Wire.read();
    Serial.println(c);
  m0=comunicacion(8);
  Serial.println(m0);
  m1=comunicacion(8);
  Serial.println(m1);
  m2=comunicacion(8);
  Serial.println(m2);
  m3=comunicacion(8);
  Serial.println(m3);
  m4=comunicacion(8);
  Serial.println(m4);
  m5=comunicacion(8);
  Serial.println(m5);
  String comunicacion(int tamano){
  char punto='/';
  int i=0;
  String variable ="";
  while(i<tamano){
    i++;
    char c=Wire.read();
    Serial.print(c);
    if (c != punto){
      variable.concat(c);
  return variable;
char c[l+1]; explain, please.
Why the crazy mix of Strings and strings?
// To convert a float to string
// n -> float to convert.
// l -> lenght of the string, default 8.
// d -> decimals, default 2.
// z -> if you want to add ceros at the left, default true.
String floatToString( float n, int l, int d, boolean z){
  char c[l+1];
  String s;
  dtostrf(n,l,d,c);
  s=String(c);
  if(z){
    s.replace(" ","0");
  s.concat("/");
  return s;
Which Arduino board and which ESP do you use ?
Do you have pullup resistors ? What is their value ?
The Arduino Uno has a 5V I2C bus and only a 32 byte buffer for I2C data.
We don't use readable text with the I2C bus. Can you send binary data ?
Koepel:
But, it is allowed (Wire.print()) and useful in some cases.
I've found this post: Increase 32 byte I2C buffer size in Wire library - Networking, Protocols, and Devices - Arduino Forum between two arduino uno, and they can send 192 bytes.
In my case I work with an arduino mega and esp-01
Did you increase the buffer size ? So with every update of the Arduino IDE your project will crash if you forget to do that ?
The Arduino Mega 2560 is a 5V board and the ESP-01 with ESP8266 runs at 3.3V.
They say that the ESP8266 is somewhat 5V tolerant, so it might work. I still prefer a level shifter between them.
You can send the same data to the serial monitor to see what you are sending. Is there a seperator between the float numbers ?
If something is not working, than take a step back and do something very simple. Try to send a byte, and test if that is 100% transferred for example one hour long. Then send multiple bytes. Then you can send maybe the float variables as binary data.
GolamMostafa:
Not in the world that I live in :wink: Okay, maybe when the binary data is different on different platforms. But the software float library is fully IEEE compatible.
Thanks Koepel!
I've just discovered the limitations of I2C in this post: https://forum.arduino.cc/index.php?topic=54439.0
There are only 5 buffers
Koepel:
