Hey All,
Sorry for committing the cardinal sin and not posting my code. I’m using the a slightly modified version of RTClib to control the RTC, running the following test script.
// Date and time functions using a PCF85263 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
#define Serial SerialUSB
#endif
RTC_PCF85263 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
if (! rtc.initialized()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
// This line sets the RTC with an explicit date & time, for example to set
// March 12, 2017 at 4:29pm you would call:
// rtc.adjust(DateTime(2017, 3, 12, 16, 29, 0));
setDualAlarms(47,0,'M');
void loop () {
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.print(" since midnight 1/1/1970 = ");
Serial.print(now.unixtime());
Serial.print("s = ");
Serial.print(now.unixtime() / 86400L);
Serial.println("d");
// calculate a date which is 7 days and 30 seconds into the future
DateTime future (now + TimeSpan(7,12,30,6));
Serial.print(" now + 7d + 30s: ");
Serial.print(future.year(), DEC);
Serial.print('/');
Serial.print(future.month(), DEC);
Serial.print('/');
Serial.print(future.day(), DEC);
Serial.print(' ');
Serial.print(future.hour(), DEC);
Serial.print(':');
Serial.print(future.minute(), DEC);
Serial.print(':');
Serial.print(future.second(), DEC);
Wire.beginTransmission(0x51);
Wire.write(0x2B);
Wire.endTransmission();
Wire.requestFrom(0x51, (uint8_t)1);
Serial.print("0x2B: ");
Serial.println(Wire.read(), BIN);
Wire.write(0x29);
Serial.print("0x29: ");
Wire.write(0x2A);
Serial.print("0x2A: ");
Wire.write(0x27);
Serial.print("0x27: ");
Wire.write(0x10);
Serial.print("0x10: ");
delay(3000);
void setDualAlarms(uint8_t setMinute, uint8_t setSecond, char toggle)
int resetMinute = setMinute + 5;
if(resetMinute > 59) resetMinute = resetMinute - 60;
switch(toggle){
case 'S':
rtc.clearAllFlags();
rtc.setAlarm(2,0,resetMinute,0);
rtc.enableAlarmINTA(PCF85263_ALARM2_MINUTES_BIT);
rtc.setAlarm(1,0,0,setSecond);
rtc.enableAlarmINTB(PCF85263_ALARM1_SECONDS_BIT);
case 'M':
rtc.setAlarm(1,0,setMinute,0);
rtc.enableAlarmINTB(PCF85263_ALARM1_MINUTES_BIT);
Without the EEPROM connected I get a nice incrementing DateTime.
With the EEPROM connected, The output is not correct, the time does not increment and is not correct to begin with.
Sample output:
2000/5/2 (Tuesday) 4:2:11
since midnight 1/1/1970 = 957240131s = 11079d
now + 7d + 30s: 2000/5/9 16:32:17
0x2B: 0
0x29: 1000
0x2A: 10000
0x27: 10000110
0x10: 100010
2000/5/2 (Tuesday) 4:2:14
since midnight 1/1/1970 = 957240134s = 11079d
now + 7d + 30s: 2000/5/9 16:32:20
0x2B: 0
0x29: 1000
0x2A: 10000
0x27: 10000110
0x10: 100010
0x2B: 0
0x29: 1000
0x2A: 10000
0x27: 10000110
The other printouts are registers I was was working on for setting alarms.
