I2C comunication with Raspberry Pi
Hallo,
I try to send some Data from my Raspberry Pi to my Arduino UNO.
Communication between 2 Arduinos works fine but i cant communicate with my Raspberry.
I don’t know if i do something wrong, an d i hope you can help me. Here the Code of the Uno:
#include <Wire.h>
  Wire.begin(4);
  Wire.onReceive(receiveEvent);
  pinMode(13,OUTPUT);
  digitalWrite(13,LOW);
void receiveEvent(int howMany)
  while(Wire.available())
    char c = Wire.read();
    Serial.println(c);
    if(c == '3')
      digitalWrite(13,HIGH);
    else if(c == '6')
and here is the code from the raspberry:
import os
import smbus
from smbus import SMBus
bus = SMBus(1)
address = 0x04
number = bus.write_block_data(address, 2, [3,4,4,6])
print(number)
In the Serial monitor i only see some boxes…
hope you have a solution for my problem, nevertheless it could python or a Raspberry problem.
Thanks
Problem solved... i recieve an int... and no char.. sometimes your mad :D
sometimes your mad
und manchmal im falschen forum, aber trotzdem herzlich willkommen...
